Projects 49-52 Chevy owners
Discussion in 'Traditional Customs' started by Bobbylee, Dec 9, 2013.
  1. Bobbylee
    Bobbylee
    Id like to see some photos of cars with a 3" drop if you guys have that. That's what I'm doing now just wondering how it's gonna look. Thanks!
  2. Bobbylee
    Bobbylee
    "2 door deluxe cars"
  3. motoandy
    motoandy
    from MB, SC
    3" in rear on avatar
  4. Bobbylee
    Bobbylee
    Is your front stock height?
  5. a990hemi
    a990hemi
    from Wisconsin
    Mine's dropped 4" all the way around. Hope this helps you gage your final result.
  6. Bobbylee
    Bobbylee
    What size tire are you running? Do you have problems turning up front?
  7. a990hemi
    a990hemi
    from Wisconsin
    I have Firestone 6-70 x 15 all the way around and I do have a somewhat limited turning radius. I ran around for awhile with the car 1.5" taller up front and that helped the turning radius out a bunch.
  8. cosmic12
    cosmic12
    Mine has 4" blocks in the rear with reverse eye springs. The front has 2" drop spindles and I did a 2" drop on the control arms, frt springs are stock. I also put pwr rack n pinion steering in it. A work in progress'
  9. iarodder
    iarodder
    Mine has De-arched leafs in the rear with 3" blocks, for a total of 5" and in the front it has 1" off the coils and lowered uprights for a total of 4", love the stance of mine but I want to eventually bag it with a four link in the rear and a MII in the front:cool:
  10. Canada Jeff
    Canada Jeff
    Do you have any front end steering clearance problems with that setup ?
  11. speaks
    speaks
    1. 4 door kustoms
    My 50 has 2" dropped uprights and steering arms, and a little over 1.5 coils cut up front.
    I have no problems with turning radius, but I am running 6.40-15's that are a little smaller than the 6.70's most people run.
  12. Bobbylee
    Bobbylee
    Looking great guys, thanks for all the pictures and info!
  13. Bobbylee
    Bobbylee
    Yea I'm gonna bag mine also, but getting married on March kinda slowed that plan down. Haha
  14. layedout49
    layedout49
    which tires are you running? car looks bad ass for a 4 door
  15. speaks
    speaks
    1. 4 door kustoms
    Thanks man, they are 6.40-15 BFG silvertowns from coker
  16. scott51
    scott51
    Bit lower than you asked about and you'll have to excuse the trailer queen pic (don't have many on my phone)
    2" drop spindles, 1.75 coils cut, leaves de-arched (2" I think) with eyes reversed and 2" blocks.
    6.70 x 15 firestones on stock steelies.
    Still need to do the alignment since blowing it apart but geometry all looks reasonable. (been signed off by the certifiers as required in NZ)
    Fronts are rubbing just before full lock but the alignment and different wheel arches I'm grafting on should take care of that. Actually looks like massaging the lip of the factory arch would get it pretty close
    Will need a small notch at the rear and slightly larger hump in the floor area over the axle pumpkin, nothing too crazy though.
    Use to run 1.5 coils cut and just 3" blocks so will see if I can find a pic when I get home
  17. Bobbylee
    Bobbylee
    I've got 3" lowering springs, and 3" blocks.
  18. hrm2k
    hrm2k
    here is our 51. we haven't lowered it yet............the body was channeled 4 inches...........and we used the wrong tail lights
  19. iarodder
    iarodder
    The tires rub just a lil at full turn but nothing bad, other than that no problems...:D
  20. iarodder
    iarodder
    Looks good love these fleetlines...what are the plans for the car overall?
  21. motoandy
    motoandy
    from MB, SC
    Yes.Will post . Another when not on tablet.
  22. layedout49
    layedout49
    Ha ! Been thinking of running those too, they're only like 1/2 smaller right ? Like it's not a crazy difference correct ?
  23. speaks
    speaks
    1. 4 door kustoms
    Yeh, there is not much difference. I decided to run those tyres after seeing how good that size looked on rob fortiers blue 53
  24. layedout49
    layedout49
    Don't know the name but I'm sure I know the car , I've seen them before and online the top of the sidewall not too say the pie crust fire stones aren't but I feel like everyone chooses 6.70 fire stones wether truck, car or got rod lol
  25. layedout49
    layedout49
    Sorry , top of the side wall how it's nice n smooth compares the the firestones
  26. speaks
    speaks
    1. 4 door kustoms
    Yes, the BFG's are smooth at the top. I also like the look of the silvertowns better than the firestones.
  27. motoandy
    motoandy
    from MB, SC
    3" lowering blocks on s10 rear and stock front end
  28. Pre-chop and post chop, both with new custom springs with 2" drop up front. Old springs and 4" blocks out back. 6.70-15 firestones.
  29. Chopped. Same as above specs
  30. Bobbylee
    Bobbylee
    Man I'm a little one sided but I think these cars just look sick slammed! Those guys in the 50's building these cars with 7-8" lowering jobs were just studs! And drive them everyday! Haha
