stewart warner oil pressure gauge issue
Discussion in 'The Hokey Ass Message Board' started by sponge, Oct 5, 2013.
  1. sponge
    sponge
    from Austin tx
    So i purchased a new winged oil pressure sender and gauge. Installed using the same wires that came off the mallory gauge which was working fine before. but when i turn the key the new gauge max's out.
    any ideas?
  2. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Wire grounded out at sender?
  3. sponge
    sponge
    from Austin tx
    1 wire from sender, maybe ill run a new wire from sender.
  4. Hotrodmyk
    Hotrodmyk
    Disconnect wire at sender abd see if gauge returns to 0, Also check and see if it is wired correctly at back of gauge.
  5. upspirate
    upspirate
    You DIDN'T use teflon tape to seal the sender did you?
    You need a good ground at the sender....no tape!
  6. sponge
    sponge
    from Austin tx
    i just disconnected the sender wire and it returns to zero.
  7. handyandy289
    handyandy289
    from Georgia
    Check polarity. May be wired backwards
  8. sponge
    sponge
    from Austin tx
    just needed the extra ground wire, works fine now. now the temp gauge i have to be worked out. Also the voltmeter pegs out at over 16vs even when connected straight to the battery.
  9. remopar
    remopar
    guage is not calibrated to sending unit.... HELLO
  10. remopar
    remopar
    what is FNG ?
  11. ROADSTER1927
    ROADSTER1927
    F---ing new guy Gary:)
  12. sponge
    sponge
    from Austin tx
    It was a bad gauge out of the box. FNG thanks
