Help to ID this GM axle
Discussion in 'The Hokey Ass Message Board' started by Edd, Oct 1, 2013.
  1. Edd
    Edd
    Can anyone ID this GM rear axle?
  2. Some kind of Dana/spicer? How many bolts?
    Dana44 with 10 bolts
  3. wheels777
    wheels777
    from York, PA
    Not a car rear
  4. mphudak
    mphudak
    from Atlanta
    Definitely looks dana/spicer. Can't see clair enough on my phone but looks similar to a 44. The ribs on the housing are throwing me off but shout make it easier to identify
  5. Edd
    Edd
  6. Not GM 10 bolt, more likely a Dana44. Look at the drain plug. It says Dana44 style
  7. mphudak
    mphudak
    from Atlanta
    What's the bolt pattern?
    Spacing between the vertical bolts isn't right for a 10 bolt
    My guess woulf be an 80s jeep cherokee/xj dana 44. Would be 5x4.5 pattern unless shafts were replaced.
  8. mphudak
    mphudak
    from Atlanta
  9. Edd
    Edd
    The pictures are all that were sent to me...guess it's a five lug wheel.
  10. mphudak
    mphudak
    from Atlanta
    Good axle if it is a xj 44. Alloy shafts are easily found for dual pattern 5x4.5 and 5x5.5. Interchange with the jeep tj (97-06 wranlger) 44 shafts. Just need drum retainer which is very common.
  11. My Dana 44 housing has those same ribs. Mine is out of a late 70's jeep with 6-lug wheels. They came either way 5-lug or 6-lug.
  12. mphudak
    mphudak
    from Atlanta
    [​IMG]That rib above the tube centerline is what is getting me. Here is the xj 44. My knowledge off 44 is limited to xj/tj rear axles and fsj/tj and ford fronts which is only a few of the 44s made.
  13. Edd
    Edd
    Thanks...That looks completely different,,here is a picture of GM axles...
  14. mphudak
    mphudak
    from Atlanta
    I can tell you with a good confidence that the original pic doesn't look like a gm axle do to the diff cover. Ribs on the gms look parrallel and on the 44 they are angled towards the yoke and above/below the tube as they go back
  15. Edd
    Edd
    Thanks...wish I had the axle in front of me for casting numbers etc. The GM stamped the axles on the passenger side tube...did the 44 do the same?
  16. mphudak
    mphudak
    from Atlanta
    I think the did also. Unfortunately I'm limited to my rockcrawling days. Visual identification was more common then stampings. But we only use a handful of axles and the only gm is typically a full float 14 bolt.
    Edit..iirc dana casts its model number in a webbing by the diff cover.
    Good reading http://www.differentials.com/technical-help/differential-identification
  17. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    isuzu rodeo dana 44
  18. gimpyshotrods
    gimpyshotrods
    If it is, it will have discs, and be 6-lug.
    Looks an awful lot like my Dana 44.
  19. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    Colorado Dana 44 is a 6 lug too
    drum Brakes
  20. gimpyshotrods
    gimpyshotrods
  21. gimpyshotrods
    gimpyshotrods
    What is the bolt pattern for the wheels? Is it the original pattern? To the ends of the axles look like this:
    Or this:
    Nut in the middle, or no nut in the middle?
  22. squirrel
    Looks like a Dana, probably a 44, which was used in about a billion different applications, from Checker cabs to GMC pickups and early T birds etc
    not enough info in that pic to identify what it's out of...
  23. gwarren007
    gwarren007
  24. Edd
    Edd
      492.7 KB
