Hey guys, Im trying to install some aftermarket rockers on an original 32 3 window body. There is not much of the original rocker left so Im trying to find some close up images to get these as accurate as possible. Even a brookville would be fine because im sure they are very close to original. Thanks for the help!
This is where im at now. Just trying to figure out how to connect the old with the new. don't know if it's supposed to have the curve up then make a piece over or if I should just cut that off and go strait to the subrail. I've found a few pics online but they are too small so I cant tell exactly how this should be.
Here's how I did mine............. Looks like you're missing a bit of material from the raised lip tp the repop rockers edge. They are tricky. Hope this helps ya out. Duane
