Features 345 Hemi Desoto
Discussion in 'The Hokey Ass Message Board' started by Gullwing, Sep 6, 2013.
  1. falcongeorge
    falcongeorge
    from BC
    I tried flow bench testing it years ago, but after I thought about it, I decided it was inconclusive, as on the flow bench, theres no way to simulate all the pulsing and backwash that happens in a running motor. One thought I had on the subject is that end gases could be pumped into the open end of the passage on the exhaust cycle, and be drawn back into the cylinder on overlap as the intake valve starts to open. Dyno testing would be the ultimate test.
  2. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Chrysler hemi with Webers.
  3. RichFox
    RichFox
    Of course the exhaust heat riser on the Ford only connects to one exhaust valve per head. On the Chrysler and Pontiac and other heads, the riser connects the two center cylinders on each head. Which may promote mixture dilution. Or as many fuel racers believe, popping back through the blower. Cement might be fine. It would scare me. And we don't really have furnaces here. Or cement for furnaces.
  4. Gullwing
    Gullwing
    TR I like the picture of Webers on a Chrysler hemi. However there are a lot of intake manifold choices for the Chrysler. The Desoto gets no love because of the lack of intake choices. In my case if you add the issue of hood clearance then its really bad.
  5. CNC-Dude
    CNC-Dude
    You could also slant the carbs toward the center of the engine some to give you more clearance for the hood. I've thought of that design myself, it sorta' copies the look of some mechanical injectors I saw on a 440 Mopar once. Since the ram tubes are staggered from the ones on the carb on the opposite bank, you can lean them over quite a bit and gain a lot of clearance. Then you eliminate the dogleg in the intake port and have a straight shot into the head.
  6. jbtine
    jbtine
    I built my own 3 duece intake for my 341 and used that remote thermostst housing. The biggest problem with that setup was from a cold engine start. As the engine warmed up heat only trickled up through the rubber return hoses. Engine heat would build to well over 210, as much as 240 before the thermostat would get enough heat to open. Cool weather was worse than hot weather. The solution was to drill the remote housing for a 1/8" pipe thread and use a small hose barb and hose to the water pump. Shown in the 2nd picture. From a cold start the engine warmed to 180 degrees and never had the temp spike. A small bypass hose. <!-- attachments --><!-- attachments -->
  7. sunbeam
    sunbeam
    Good stuff jbtine
  8. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Would it have been easier to start with a Chrysler Weber intake, and modify it for your Desoto? Basically cut the flange off and add a Desoto flange?
  9. Gullwing
    Gullwing
    I don't know the answer to that. I considered it I didn't have one to play with. I was a little leery to buy one then cut it up.
  10. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    I can understand that.
  11. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    That's a nice lookin outfit.
  12. jbtine
    jbtine
    I got the idea from an article posted on the HAMB about 6 years ago. I don't know if it is still on here so here it is if it is any value to you.
  13. Gullwing
    Gullwing
    [​IMG][/URL][/IMG]
    I just got my manifold back from the machinist. Welded the two pieces to the base. I can then cast them as one piece and save me some cost.
  14. Gullwing
    Gullwing
  15. Gullwing
    Gullwing
    It's taken a while but I finally got my intakes cast up. This is a unmachined casting. I will probably be a few weeks but I will post a pick after I machine them and polish them.
  16. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    Being that the carbs are side draft, remove everything but the butterflies, and go with a Megasquirt type injection by installing injectors in the manifolds. It will keep the Weber experts guessing if they can't see the injectors. Just a thought.
  17. blown36
    blown36
    from Oz
    Wondering how this ended after the prototype?
