Guys I have what I believe is a 250 chevy motor, here is casting numbers: 3921968,G253 and stamped by dist.H0730PC, bellhousing cast number 3925505 and the info I have so far is 64-76 250 according to casting numbers but would like to id the application. Thanks.
Take a look at the website: www.inliners.org They are a wealth of information for any inline engine. Normbc9
Hoop98 where can one find these break downs. I to have an engine that I would to Id the specific application. All I can find is the same broad information like 55 Dude. Sent via Western Union Express
http://www.novaresource.org/codes.htm was where i found the suffix code. Casting numbers http://www.castingnumbers.info/site/search/3921968
Hey 55 Dude, question. Are you sure the Date code is G253, that would be an engine cast July 25 in a year ending in 3. The code H0730PC decodes as the engine being assembled at the Hydramatic Engine Plant on July 30 or 5 days after casting so that makes sense. The PC code, is a 230 in 65 and 66, a 250 in 67. So no year ending in 3, just curious.
Since the 230 and 250 are the same bore size and the blocks are cast from the same patterns.....what is measuring the bores going to tell him.
I know that also, but I was questioning how he thought actually measuring the bore was going to tell him the difference between the 230 and 250 since they are the same bore size.
i was able to id the 250 i am working on by looking up the numbers in my 1973 motors manual. it had a nice listing and even told what type of car, what transmission was behind it and a few other options.
