Does any one know a good frame builder in the Louisville, Lexington area. I have a 32 frame with all the components that I needed welded and assembled. Jeff
Jeff: Contact bruce bowe here on the hamb He's listed as bruce bowe in the list of members. Don't know if he has time but can point you in the right direction. Tim
Jeff: Get any help yet? I can supply contact info for the two mentioned above if needed. Tim Whitaker
Bruce has a frame jig set up in his shop to do 32 frames. He is currently working on a 32 sedan of his own. He goes by Chicosuave on here. If you can catch him he might be able to weld it together for you. I do know he is in a crunch to get his car finished for our Texas run in April 2014.
if cincinnati, ohio is not too far , we are dropped axle productions. have done several 32 chassis for hamb members. check out our website. www.droppedaxleproductions.com
