Projects 61 Ford unibody build
Discussion in 'The Hokey Ass Message Board' started by JakeDW, Nov 10, 2012.
  1. JakeDW
    JakeDW
    from Missouri
    Shaft to rack setup.
    Jake
  2. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    looks good man, keep up the good work. hopefully they dont shut down your thread like mine did
  3. JakeDW
    JakeDW
    from Missouri
    Thanks man I am about to redo the top 4 link bars and cross member then when that's done it really will be on to the motor install.
    If they feel the need to delete my build thread it's their choice I hope at some point it gets moved to traditional styled hot rods and customs.
    Jake
  4. JakeDW
    JakeDW
    from Missouri
    Start of the crossmember the curve will replace the top part top bars will be relocated to the top of the pumpkin and will be triangulated down to the top of the frame rails.should get it done this weekend.
    Jake
  5. Excellent build!
  6. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    how far apart did you make your cuts? i want to do something like that for my back half
  7. JakeDW
    JakeDW
    from Missouri
    Started with a center cut and cut every 1 inch then bent it till the gaps were touching then went back with a 4 in grinder with a cut off wheel and re opened up the gaps then bent it shut agine.
    Jake
  8. JakeDW
    JakeDW
    from Missouri
    Rear top bars and cross redone still need to adjust the angle at ride height and cut off the other axle tabs and grind down the curve where it's welded back together.
    Jake
  9. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    looks so much better
  10. JakeDW
    JakeDW
    from Missouri
    Thank you.I am going to make another squar curved style cross for the shocks allso.
    Jake
  11. JakeDW
    JakeDW
    from Missouri
    Kyle came over and did some stripes.
    Hood
    Jake
  12. JakeDW
    JakeDW
    from Missouri
    Dash
    Jake
  13. JakeDW
    JakeDW
    from Missouri
    Tail gate sorry pics are crappy phone pics there is a third color that does not show up in the pics on the tail gate and hood it's a teal color close to the trucks paint color.
    Jake
  14. milanperformancecycle
    from milan t.n.
    Man this is a kick ass truck. I just sold my 61 unibody to find my 54 bel air. I'm subscribing to this one.
  15. JakeDW
    JakeDW
    from Missouri
    Thank you
    Jake
  16. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    man i need to get back to the shop...your truck is making me want to get back out to my shop
  17. JakeDW
    JakeDW
    from Missouri
    I keep putting off taking it back apart so I can put it up on stands and mocking up the motor and trans in it lol.
    Jake
  18. JakeDW
    JakeDW
    from Missouri
    Kinda stuck the motor in to see if or how much needed to be cut out.
    Jake
  19. JakeDW
    JakeDW
    from Missouri
    Yup had to cut some out.I will get it up on jack stands tomorrow to really fit it up.
    Jake
  20. JakeDW
    JakeDW
    from Missouri
    Came across this vintage peep mirror.
    Jake
  21. JakeDW
    JakeDW
    from Missouri
    Up in the air for a while for motor trans mock up.box the rest of the frame ect.
    Jake
  22. JakeDW
    JakeDW
    from Missouri
    Center of the trans mount.
    Jake
  23. JakeDW
    JakeDW
    from Missouri
    Start of the sides.
    Jake
  24. JakeDW
    JakeDW
    from Missouri
    Trans mount
    Jake
  25. JakeDW
    JakeDW
    from Missouri
    Motor mounts in.
    Jake
  26. JakeDW
    JakeDW
    from Missouri
    Now on to more boxing ect getting the drive shaft to the rear end is gona suck lol.
    Jake
  27. JakeDW
    JakeDW
    from Missouri
    Got the last of the factory crossmembers out and the rest of the frame boxed.Now time to get the drive shaft shortened and tunnel the torque box and some floor bracing ect.
    Jake
  28. JakeDW
    JakeDW
    from Missouri
    Got everything tunneled for the drive shaft once I get the driveshaft back from being shortened I can make sure its not hitting anything then I will box back where I cut everything out.
    Jake
  29. Jbuhl1954
    Jbuhl1954
    Great build thread!! I am for sure subscribing!!!! Badass!!
  30. JakeDW
    JakeDW
    from Missouri
    Thanks man.
    Jake
