Super fast blinkers
Discussion in 'The Hokey Ass Message Board' started by kcbeardclub, Sep 12, 2013.
  1. kcbeardclub
    kcbeardclub
    from KCMO
    What would cause the blinkers on my car to blink about a thousand times a minute? I have a guide turn signal, 3 prong flasher and all of the lights work properly.
    T
  2. Check your grounds
  3. seb fontana
    seb fontana
    from ct
    May be just the flasher is weak or there is more load than it is rated for..An electronic flasher cures all..
  4. pitman
    pitman
    Any chance that you have a 'trailer' type flasher in there?
  5. SMOG_GUY
    SMOG_GUY
    from Dinuba
    On old bi-metallic flasher types they blinked slower with a bad bulb. Or too fast wih too high of a load like incorrectly installed bulb, for example.
    On newer solid-state flasher types they blink faster with a bad bulb. Or bad connection or ground.
    But check bulbs first.
  6. oldolds
    oldolds
    There are different flashers, they are based on the load. Could also be just a bad flasher.
  7. Are any of your bulbs LED? They will cause the flasher to blink much faster.
  8. kcbeardclub
    kcbeardclub
    from KCMO
    No LEDs here, I'm still running the old 6volt system. I've got double filament bulbs and they are all working. Still trying to wrap my head around all of this electrical crap, learning as I go. I have the 6 volt 535 32CP-Max 6 flasher. If there is a bad ground (which chances are, there is somewhere) where should I start looking?
    Thanks for the help.
    T
  9. jmpowie
    jmpowie
    You need more of a load on the flasher. They are made to flash fast when a bulb bruns out to let you know there is a problem. If you have LEDs they draw less amps and flash faster.
  10. kcbeardclub
    kcbeardclub
    from KCMO
    I put in a brand new flasher and had the same problem:confused:
    T
  11. sunbeam
    sunbeam
    I never could understand on a US made car you loose a bulb and they won't blink but on foreign cars you loose a blub and they blink like crazy.
  12. oldolds
    oldolds
    Add another bulb and see if it slows it down.
  13. kcbeardclub
    kcbeardclub
    from KCMO
    Where?
  14. oldolds
    oldolds
    Just something temp. Add it where it is easy.
  15. Think of the flasher as a circuit breaker that is designed to reset itself quickly after the current load is removed from the circuit.
    To keep the math simple let's say the flasher is designed to open when there's a 5 amp load on the circuit. And lets assume that the park lamp and tail lamp bulbs each draw 3 amps. You hit the turn signal switch and the flasher sees a total load of 6 amps. The circuit breaker in the flasher opens the circuit temporarily turning off power in the circuit and the bulbs go out. With no load on the circuit the breaker resets itself and restores power to the circuit and the bulbs go back on. Then the whole cycle repeats itself until the power is cut off at the turn signal switch.
    If a bulb is burned out in the circuit then the flasher may only see a 3 amp load when the turn signal switch is on. As a result the breaker may never open and the bulb will never blink. Or it may only blink less frequently depending on the actual amp rating of the flasher.
    Now consider what happen when you add another turn signal bulb to the tail lamp or connect trailer light wiring to the circuit. You end up with three bulbs in the circuit and a total of 9 amps load feeding thru the flasher. As a result the circuit breaker in the flasher opens more quickly and frequently to deal with the increased amps. A short to ground in the circuit will also affect the amps.
  16. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Excellent explanation ClayMart.
  17. Check and clean all your grounds.
  18. bobwop
    bobwop
    from Arley, AL
    did you check to make sure the blinker fluid is not low?
  19. ClayMart is 100% correct, current draw with traditional flashers sets the pace. Too fast could also mean a partial short
    Later,
  20. tfeverfred
    tfeverfred
    Are you using the right bulbs for the turn signals. Switching 1156 & 1157, sometimes made them blink faster. I had an old Mustang that would do that. Damnedest thing I ever saw.
  21. kcbeardclub
    kcbeardclub
    from KCMO
    I did and it was full until I spilled it all over the grill......... If by blinker fluid your referring to a tasty frosty PBR tallboy
  22. kcbeardclub
    kcbeardclub
    from KCMO
    hmmm I have no idea, I will look into that. Thanks
    T
  23. stimpy
    stimpy
    actually check the double filament bulbs to make sure a filament didn't break and is shorting out against part of the parking light circuit in the bulb ( creates a high load as it completes the other circuit and try to feed its lights ) . we have this happen alot with trucks
  24. realsteel40
    realsteel40
    Flashers will do it to, try throwing a one in
  25. kcbeardclub
    kcbeardclub
    from KCMO
    If a filament breaks, will the light still work? They all four work with running lights as well as "high" beam for the signal, all flash at the same time, just super fast and the indicator light on the switch is working as well.
  26. stimpy
    stimpy
    the filiment can break and part of the filiment can drop down and touch the other filiment in the bulb and it would complete a circuit , and make the bulb work like normal as found its circuit ground to complete the power loop. but would act like a ghost ground and not light some of the other bulbs and creat e a high amperage situation from the resistance of the other bulb filiments if they do not or light up .
    ussualy when this happens the dash turn indicators if it has any would lightly glow when the lights are on signals off .or you get a slight buzzing from the flasher can.
  27. The Drunk Man agrees! :D And it's always been my policy to never argue with a Drunk Man! :rolleyes:
  28. Possibly one of the turn signal bulbs is burnt out. HRP
  29. Deuce Daddy Don
    Deuce Daddy Don
    Other than a bad ground, HRP is right!
  30. kcbeardclub
    kcbeardclub
    from KCMO
    OK, checked the grounds, good. Tried adding a bulb inline, no change, put in brand new flasher, no change. It is reading 2.5-3 volts at the bulbs as it blinks, also seems to have an intermittent super fast blink to kind of fast blink, with no pattern or rhyme or reason. Still stumped here.
    T
