DP40lf; what additive?
Discussion in 'The Hokey Ass Message Board' started by anteek49, Sep 8, 2013.
  1. anteek49
    anteek49
    I found several quarts of DP40lf primer that I'd like to use. What activator do I need?
  2. FunnyCar65
    FunnyCar65
    from Colorado
    DP401LF or DP402LF
  3. 400 4spd.
    400 4spd.
    Note that the 401 hardener has to be added at least 1/2 hour before it can be sprayed. The 402 does not have an induction time required and can be sprayed right away. Pot life is also longer with 401.
  4. 40fordtudor
    40fordtudor
    that's good to know---thanks.
  5. towithome
    towithome
    from oregun
    Use the 401, it makes dplf a decent epoxy. Avoid the 402.
