Projects Morgans 51 chev sedan build up (Australia)
Discussion in 'The Hokey Ass Message Board' started by Morgan91, Oct 12, 2011.
  1. Deucefanny
    Deucefanny
    from Australia
    Looking good. Is it gonna make Chopped?
  2. Morgan91
    Morgan91
    from Australia
    Cheers man. Chopped is what in aiming for will just be in primer or something but hopefully I can drive it there! Worst case il trailer it but I really wanna make the road trip, it's about 5 hours for me.
  3. Morgan91
    Morgan91
    from Australia
    Last night got all the airlines all finished up and got it off the hoist. Old door frames sand blasted an primed, and while i was waiting for those to dry i started messing around with the hand brake mechanism. Pulled one out of a land cruiser I totaled a few months back and it seems to work Nicely in next to the seat. Just gotta make a cable now
    Drove it outside this morning while I was cleaning up the workshop. Looks so good out in the sun!
  4. Morgan91
    Morgan91
    from Australia
    Got the inner quarter supports all welded in tonight. Also found a crack on one of my rocker covers that il have to try and fix.
  5. Morgan91
    Morgan91
    from Australia
    Some updates from the last few days, been trying to find another pair of doors cause the ones iv got are twisted a bit and I'm chasing my tail trying to fix them. Iv got a lead on a set so hopefully that pays off! Just little bits and pieces of progress as iv Ben doing heaps of overtime lately and was sposed to have a weekend off last weekend but got called up to work. Anyways, got more sound deadening stuff and finished off the front floor sections and firewall. Welded up a corner of where the pillar joins the sill. Got the hand brake all functioning and cut out some inner pieces of the rear window frames to fit a window in. Started making new door skins as well but hopefully I won't need them.
  6. ausbuick
    ausbuick
    good work bro
  7. jeffrob
    jeffrob
    Pictures and explanations on this thread are top notch, read through at least 3 times.
    Awesome work, thanks for posting!
  8. Morgan91
    Morgan91
    from Australia
    Thanks mate!
    Progress has been happening iv just been flat out at work so haven't had much time to update this thread.
    Got some other doors as the other ones I had were twisted and just to much work to fix.(I might fix them one day but I'm on a tight time frame here at the moment haha iv got 50 days to get this thing all straight and running properly, in primer and all back together so I can drive it to chopped! . Anyway. The doors are from a coupe not a two door sedan so il have to modify the top window frame which isn't a big deal but they are in a lot better condition then the others are and they are probably the only other spare doors in the country! there is a couple rust pin holes and a few dints and the check strap areas are damaged but all pretty simple stuff to fix. Also finished off the sound deadening and started routing the wires and what not through the cabin, also all the gauges work now to!
  9. Deucefanny
    Deucefanny
    from Australia
    Choooooopppped!!!!;)
  10. Morgan91
    Morgan91
    from Australia
    Can't wait!
  11. ausbuick
    ausbuick
    WOW those coupe doors really make the 4 door roof look tall!!!!!!!!!!!!!!
    Cheers Darren
  12. Morgan91
    Morgan91
    from Australia
    Haha they sure do. Hopefully my roof won't stay that tall next year!
  13. thewaxhead
    thewaxhead
    Looking sick mate! Hope to see it at Chopped. I just read the 16 pages, and been following the progress shots on instagram- its an inspiring build
  14. Morgan91
    Morgan91
    from Australia
    Thanks man, hopefully it will be at chopped! Can't wait. Do you think your 51 will make it over in time?
  15. Outback
    Outback
    from NE Vic
    Hope to see it there Morgan! looking good!
  16. Morgan91
    Morgan91
    from Australia
    Thanks for the positive comments guys! Been working away up the snow for the last few days and haven't been able to come down. Down now and I'm sposed to have the weekend off so hopefully there will be some more updates this weekend!
  17. Morgan91
    Morgan91
    from Australia
    Been working flat out but have had a bit of time on the chev. Got the door tops welded on from the other doors, got all the door gaps pretty close to perfect and dad helped me with some tapping up of the body work and doing some lead loading and started some bog/ fiberfill work yesterday. Decided against filling over a sealer as dad thinks it bites in better to the raw steel, my plan was to seal it then bog work but he has been doing this Job for more than 45 years so I listen to him when he suggests somthing. ImageUploadedByH.A.M.B.1377520730.218548.jpg
  18. hughesy
    hughesy
    Looking good there Morgan..
  19. Nice work keep it up!!
  20. Morgan91
    Morgan91
    from Australia
    Thanks guys!
    Update, pretty much all the lead and bog work is done on the quarters, just have to do a bit more work on the doors with the nail gun and stuff and the front sheet metal just needs to be rubbed back a bit. But the quarters are in sealer, but because I'm working away this weekend probably won't get in primer until Monday or Tuesday night. Iv got a tinted primer that I'm gonna paint the whole car with and just drive around like that untill after its chopped and a few other custom things like headlights and tail lights are all finished up.
  21. Looking good Morgs
  22. ausbuick
    ausbuick
    Sweet
  23. Morgan91
    Morgan91
    from Australia
    Bit of an update got the gaurds, bonnet and boot all primed up in the tinted primer last night and the main body primed tonight, still have to get the doors straight and primed but il be able to start putting the inside in it tomorrow night. The color of the primer isn't as subtle as I had thought it would be in my head when I ordered it but its growing on me and its only temporary.
    Also got a new tire to replace the ripped up one that started this whole build, talk about snowballing.
  24. ausbuick
    ausbuick
    Bloody bright alright...........
  25. Morgan91
    Morgan91
    from Australia
  26. Deu55
    Deu55
    Wow come a long way,looking good...
  27. hughesy
    hughesy
    That looks cool
  28. Morgan91
    Morgan91
    from Australia
    Couple more pics, should have the doors primed tonight after work, last night I got all the seatbelt mounts made/moved from where the old four door ones were and the three belts in the front(not gonna put any in the back because there's not going to be a proper seat in there) got the radio wired up and tested it and finalized the patterns for the glass that are getting picked up today.
    The following photos are from my mate Chris Cooper that came up on the weekend with another mate of mine and go Lincoln that we lowered.
    And one of yours truly all wrapped up ready for some overhead MIG welding haha.
  29. ausbuick
    ausbuick
    Fair too say that your Chebby is HIVIS now sporting that green primer
