Features Who's Building a T?
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 19, 2011.
  1. Thanks! I'm pretty sure this is a '26, the firewall has 4 small rivets and 2" webbing (on the inside) for fuel tank anti-squeak purposes, the door latches have 3 screws instead of 4 (27's had 4 screws), and my sill plates are screwed to the rockers.
  2. oj
    oj
    I made some progress on mine, it must be a '27.
    The seatback was handformed at somepoint in its' life. It was kinda rough by todays' standards but i didn't want to replace it, i spent some time on it and i think it'll work just right..i feel it belongs on the car.
  3. 34PEECUP
    34PEECUP
    This my latest t bucket project
  4. Bigcheese327
    Bigcheese327
    Got a ways to go, eh? ;)
  5. 34PEECUP
    34PEECUP
    Try photo agin
  6. Hackerbilt
    Hackerbilt
    Hahahahaha!!! :D:D
  7. Hackerbilt
    Hackerbilt
    Looks nice and well thought out!
  8. Hot Rod Nut
    Hot Rod Nut
    Here's mine, and it's for sale
  9. Just a quick question. Do any of you know where a person could get a replacement belt line moulding for the back of a 26 Tudor sedan? I know the moulding is part of the upper half of the body, but does anyone make a strip that could replce it? I have a friend and his is rotted out at the upper edge of it and someone in the past tried to weld it back to gether with horrible results.
  10. I helped restore a 27 and its not reproduced as far as I know. The options we had was either make a new piece or fix what we had.
    My trophy case has a trophy case!
  11. Ragtop
    Ragtop
    If you put your location in your profile someone could probably recommend a metal shaper that could do that for your friend
  12. Noah*
    Noah*
    Got my new windshield installed this weekend
  13. Noah*
    Noah*
    Got my top installed....
  14. fattoy
    fattoy
    Just found this site and I'm in heaven. Just started a build down here in New Zealand. Bought a part built project that was done by a guy called Mercury Charlie. Not many T's in NZ and it much info, so this is fantastic. Just started putting a motor in it. ImageUploadedByH.A.M.B.1375939474.778743.jpg ImageUploadedByH.A.M.B.1375939499.036660.jpg
  15. Hi and welcome fattoy, there are a lot more steel T's here than you would think. Yours looks rather cool. JW
  16. fattoy
    fattoy
  17. pnevells
    pnevells
  18. MERCURYGUY
    MERCURYGUY
    Gatherning parts. I currently have a 1927 Tub. I want to make it full fendered. Still looking for a chassis to put it on. I also have a 27 T 2-door sedan.Have most parts to put it together.Just need to get it out of the barn and put some heat on it.
  19. Babyburr
    Babyburr
    from Hurst, TX
    Just saw this thread. Here is where I am right now.
  20. tfeverfred
    tfeverfred
    Man, that's a long wheelbase.
  21. Blue One
    Blue One
    from Alberta
    That's what I thought. Looks like at least 12" ( maybe more) should be cut out of the front to make it look right.
  22. Babyburr
    Babyburr
    from Hurst, TX
    120" wheel base. Yeah, it's long and has a pretty smooth ride being long. I am going to move the radiator back to fill in that wide gap. I think that will help the look of this long T.
  23. Blue One
    Blue One
    from Alberta
    I think that will just make it look different. I think it will still look funny with the front end stretched way out there in front of the rad.
    I don't see anything but a drastic frame shortening and moving the front end back to where it should be to get the scale and proportions more pleasing to the eye.
    The ride would still be decent.
  24. NortonG
    NortonG
  25. Skam213
    Skam213
    picked this up.... not sure year, maybe one of you guys can tell?
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    That is an early twenties Buick I believe. Or Dodge.
  27. Skam213
    Skam213
    Yeah? Any ways to tell? Any ideas where to look?
  28. fiftyv8
    fiftyv8
    from CO & WA
    We are kinder getting away from this T thread topic a little, but I did ask about this body some time back and was told it was a 1923 Dodge.
    Your body looks pretty similar to it.
    Anyways, good luck with your project and may I suggest you start your own question and build thread so you will get more specific info.
  29. bambbrose
    bambbrose
    from So. Utah
    Piecing together a 27 roadster right now.
    Current plans:
    -27 roadster
    -32 frame
    -y block 292, 4 speed manual
    not much else decided, but that is the backbone of the project.
  30. need louvers ?
    need louvers ?
    I'm in...
