Older ford tranny I.D.
Discussion in 'The Hokey Ass Message Board' started by steve185, Aug 3, 2013.
  1. steve185
    steve185
    This tranny was in my 32 Ford frame when I got it. I can't find any markings on it. I was hoping it was a 32 and the serial number would be on it.
    Anyone know what year it's from, is it worth anything to anyone?
    Thanks Steve
  2. Looks like a '32 four banger trans.
    Al.
  3. Model A Gomez
    Model A Gomez
  4. steve185
    steve185
    Do you know if there should be a serial number on it?
    Thanks
  5. four banger 27 T
    four banger 27 T
    No serial number on the B trans. The serial number was on the B engine.
  6. 4-port Riley
    4-port Riley
    It is a 32-34 Model B tans. The engine numbers on 4 cyl. engines in those years were on the upper bell housing. On the V8's the number was on the trans. Judging by the shifter it still has early gears inside the case.
  7. No serial number on B engine. The serial number was on the flywheel housing for the Model B. The shifter tower is '32 based on the mounting bosses for the emergency brake. The rear mount looks like '32.
    Charlie Stephens
  8. alchemy
    alchemy
    Something funny going on with the output though.
  9. Carter
    Carter
    The clutch arm looks like 32 also.
    Indeed.
