HELP! WHAT IS POB #4 56 olds head install
Discussion in 'The Hokey Ass Message Board' started by MR K., Jul 14, 2013.
  1. MR K.
    MR K.
    So I am doing the heads on my 56 olds. The old manual book says to spray pob #4 on the head gasket. What is that. Is there something I can use in place of it.
  2. flameboyzero
    flameboyzero
  3. MR K.
    MR K.
    can I use a copper spray instead??
  4. gonzo
    gonzo
    I dont believe modern head gaskets require any sealant. I did not use any when I assembled the head gaskets on my 56 Olds motor and it was fine.
  5. flameboyzero
    flameboyzero
  6. flameboyzero
    flameboyzero
    correct not required on new style gaskets, but can't hurt either
  7. Paul
    Paul
    Editor
    I use copper coat on my early Olds motors, spray and install wet
    was having an occasional blown gasket when installed dry
    haven't had a failed head gasket since
    even with high compression and blown setups
  8. MR K.
    MR K.
    Thanks guys!
  9. 50 Fastback
    50 Fastback
    I use Edelbrock 9300 Gasgacinch Gasket Sealer on head gasket and intake surfaces.
