SBF diag help
Discussion in 'The Hokey Ass Message Board' started by dvlscoupe, Jul 9, 2013.
  1. 59 brook
    59 brook
    way too much fuel pressure edelbrocks should run 4-4.5 psi
  2. jwray
    jwray
    from Omaha, Ne
    Another question is, Can you see fuel dripping from the boosters while it is idleing?
  3. dvlscoupe
    dvlscoupe
    I don't see any fuel dripping. I thought maybe I was having a boil over issue, bad float, etc. so I was looking for that, I've managed to get it to idle down to around 850 RPM smoothly, and the vacuum gage is smooth, It's still just stalling in reverse/park though I can keep giving it gas to continue running, it just runs rough.
  4. jwray
    jwray
    from Omaha, Ne
    Can you hear a loud hiss from the carb area?
  5. dvlscoupe
    dvlscoupe
  6. jwray
    jwray
    from Omaha, Ne
    If the sound is not coming from the throttle blades, and is coming from outside the carb then you have a vacuum leak. Are you sure you plugged all the unused ports and that there is a plug in the back of the carb. What about the intake, did you move a vacuum line from the intake to the carb and forget to plug the intake?
  7. dvlscoupe
    dvlscoupe
    I only have my vaccum advance and trans line to connect. The Brake booster port in the back is plugged. Both ports in the front are used by the advance and trans and the PCV port is connected to the PCV. I'll have to try some more starting fluid to see if I can find a leak again. I have adjusted the electric choke fully counter clock wise so I'm not on the high speed idle screw so maybe it's pulling air from that being open.
  8. jwray
    jwray
    from Omaha, Ne
    What demon carb did you take off the car, was it an AFB style or a Holley style?
    I think at this point I would take all the vacuum lines off the carb and plug all the ports and see if that helps.
    Where does the hiss come from, inside the carb or outside?
  9. dvlscoupe
    dvlscoupe
    It's a holley style carb. The hissing is coming from inside, it's a sharp distinct sound that gets a little quieter once the engine warms up.
  10. .049" plug gap is way too big. Bring them back to .035"
  11. Use a propane bottle (don't light the torch) to find your vacuum leak. Just don't leave the valve open for more than a minute at a time. I've found it is easier to get the nozzle end of the propane torch around carburetors and intake manifolds than trying to spray starter fluid everywhere.
  12. dvlscoupe
    dvlscoupe
    Oops. Tha should have been .040
  13. VTjunk
    VTjunk
    .040" is fine for an electronic ignition. I was fouling autolite plugs with regularity, switched to ngk and haven't had much issue with them.
  14. jwray
    jwray
    from Omaha, Ne
    Did your old carb have 3 vacuum fittings on it?
    I am sure when you find it, it will be a vacuum leak on the manifold some where or maybe a line going to to the dist, brake booster, or PCV is cracked and leaking.
  15. dvlscoupe
    dvlscoupe
    It did have 3 ports, PVC, trans, advance. I'm gonna get the starter fluid out when I get home and see what happens. I'll probably swap the plugs once I get this straightened out so the ngk tip is helpful.
  16. dvlscoupe
    dvlscoupe
    So I can stall it out spraying starting fluid between the carb and intake. I put the adapter plate with a gasket on top and bottom of the plate, bolt it all together and it still stalls with starter fluid being sprayed and when put in gear.
  17. nexxussian
    nexxussian
    Warped flange?
    Adapter plate to get vacuum?
    Please forgive me if I missed the purpose of the adapter earlier.
  18. nexxussian
    nexxussian
    Warped flange?
  19. dvlscoupe
    dvlscoupe
    The adapter is just a thin piece of steal so the base plate of the car matches the intake properly.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
    What intake are you running? Curious why you would need an adapter.Most Ford aftermarket intakes are square bore for Holley/AFB pattern and would not need an adapter,a heat insulator yes.
  21. nexxussian
    nexxussian
    What Jeff said.
  22. dvlscoupe
    dvlscoupe
    It's and edelbrock performer intake.
  23. JeffB2
    JeffB2
    from Phoenix,AZ
  24. nexxussian
    nexxussian
    Do you use the steel plate to anchor your throttle cable?
    If not try it without, might fix the problem, might not, worth a shot.
  25. dvlscoupe
    dvlscoupe
    I added the plate because it was sucking air between the base plate on the carb and intake manifold. Turns out it does it with or without that plate.
    On another note I straightedged the flange on the intake and it's not warped.
  26. VTjunk
    VTjunk
    so you straight edged the intake, and its fine. How about the carb? I've never seen one that was warped but I guess its possible. By adding a plate and an extra gasket to the equation you may be compounding the problem. Not sure what you're up against now, thought it was just a tuning issue or bad plugs/wires
  27. dvlscoupe
    dvlscoupe
    The base plate is good, I took the plate out used two gaskets and sprayed it with starting fluid again and same thing. I should say I'm spraying the shit out of it so is it possible that's why I can get it to stall out?
    I've decided to start checking the ignition system, the coil resistance seems off but I would think it wouldn't run at all if the coil was actually bad.
    Next I'm going to try testing the electronic conversion module. We'll see.
  28. VTjunk
    VTjunk
    What type of module are you using?
    The starting fluid should make the engine idle pick up and run smoothly for a few seconds if its finding a vacuum leak, not stall it.
  29. dvlscoupe
    dvlscoupe
  30. Deuces
    Deuces
    Bingo!
