I am building a Hot Rod out of a 1941 Coupe. I need to wire the gauge panel. Which side of the gauge does the sending unit attach to. See attached pictures. <!-- / message --><!-- attachments -->
take a 6v battery and test it. Whatever is marked Positive would more than likely be the sender side, since it was positive ground.
