Features GAS PEDALS....picture thread
Discussion in 'Traditional Hot Rods' started by Kiwi Kev, Jan 2, 2010.
  1. ShakeyPuddin55
    ShakeyPuddin55
    Original Cragar pedal with a hole drilled through the G
  2. choke
    choke
    Moon dual setup.
  3. 340HilbornDuster
    340HilbornDuster
  4. OK, so I have collected enough gas/drum pedals to outfit the entire percession section. I figured it was about time to actually one of them in the car! I had always planned on using the Ghost pedal in the first picture, but when I went to mock it up, it was freaking HUGE in there! So, back to the stash of pedals. I have several of the Ludwig "Speed King" pedals, but they didn't quite fit or look right either. Then I found this really old "Ludwig" pedal, and it was just the right size. Plus, it already came with the holes in it from the factory, so it matched the steering wheel and the shifter perfectly. I'm sure that there is some drum geek out there banging his head on the keyboard right now, but too bad! What do you think? I know...carpet is on the list of things to do.
      519.2 KB
      513.5 KB
      520.1 KB
  5. Looks good to me!
  6. 35ChevSedan
    35ChevSedan
    Here's the one I'm putting in my '35 - it's a Ludwig "New Speed Pedal" made from 1936-1950.
  7. 35ChevSedan
    35ChevSedan
    Looks good! How did you attached it over your other pedal?
  8. Ha! I have one like that, too!
    The one that I used is slightly older, from the 1920's I believe. Where you have a two piece pedal with a "hinge" to pivot, mine is a one piece design with "ears" on the back allowing it to pivot, like a see-saw. I drilled all the way through the existing pedal, and ran a long cotter pin all the way through both "ears".
  9. The allusive and highly overrated barn door gas pedal. :D HRP
  10. ...but was the barn built pre-'63?
  11. 64 DODGE 440
    64 DODGE 440
    from so cal
    Goes good with the light weight ventilated floor.
  12. Ledfut
    Ledfut
    I NEED to find one of these!
  13. Me too.
    -Brent- likes this.
  14. 55belairx2
    55belairx2
    Haven't seen one of these before...any ideas? Tried to buy it on ebay.
  15. Barn Find
    Barn Find
    from Missouri
    These are all really cool. Thanks for posting these photos.
  16. I have some more pedals to add. 3 were gifts and the others were swap meet buys in the $5-$15 range.
    First is this Glenwood marine pedal....
    Another marine pedal, this time from New Zealand. East Coast Bays Marine......
    National....
    This is a weird one, just a smooth rectangle....
    Someones high school project. Not a great pedal but a lot of character with the Wilson High, 61 scribed in the back.
    For $5 this Kenworth pedal can join the collection....
    I have no idea what the original application for this one was...
  17. Here is a really nice little pedal I picked up a while ago at the CHRR swap meet. It is a little bit bigger than a dimmer switch pedal and high quality, I was told it was made for running those scaled down engines. I have a secret plan for it.
  18. Don't keep us hanging any longer...what's the secret plan?
  19. docmike
    docmike
    These are really cool. I never knew that there were so many different makes. I've thought about looking for a set that match left to right and then use them for floorboards on my Harley.
    Doc
  20. Muttley
    Muttley
    Moon has them.
  21. Kustomism
    Kustomism
    Not quite as impressive as some collections !! But ImageUploadedByH.A.M.B.1378972848.717538.jpg ImageUploadedByH.A.M.B.1378972994.334343.jpg
  22. Leviman
    Leviman
    I see this, scroll through the whole thread thinking "Sweet! I've got that rectangular moon pedal, and no one else does." Then the very last post...
    Well, actually I suppose mine's a bit different.
  23. 1936NZ
    1936NZ
    Here is a hydraulic set up from New Zealand :D don't know if it's native or not?
    Looks like your M & S hi power?
    It's from a river jet boat of unkown age?
    I have the slave cyl and once it gets new seals,
    it's going in the 36.:D:D:D
  24. Kev,,it's about time to admit you have a problem! :D HRP
  25. I don't have a problem, I'm a little worried about everybody else though.
    37hotrod....Secret plan cannot be revealed yet due to procrastination.
  26. 53 COE
    53 COE
    from PNW
  27. Hell Kev, that's no secret! I have stuff that I haven't even gotten around to putting off yet!
  28. I saw these at a yard sale, 3 for ten bucks so I guess they can join the collection.
  29. Here are some cool pedals seen at the CHHR.....
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Wow! That 1st one is so light, if you threw it in the air it wouldn't come down.
