41 Willys coupe license plate bracket & light location
Discussion in 'The Hokey Ass Message Board' started by Steves32, May 12, 2013.
  1. Steves32
    Steves32
    from So Cal
    I searched- didn't find what I need.
    Deck lid has no holes for reference.
    1st off-
    Can someone measure from bottom lip of lid to mounting holes or CL for each. Can you include a pic?
    I have the bracket for plate. Is there a gasket that goes between bracket & body?
    I have the repro light housing, the base gasket & the bulb but no bulb bracket.
    What does this bracket look like & a pic? Anyone have a spare? I can make one if I know what it looks like.
    2nd part of question
    I'd rather run it below the deck lid if possible I'm not running bumpers so that area is wide open. Any one else mounted one there.
    I'd like to see what you are running.
  2. Weasel
    Weasel
    Steve - here's a photo for reference - don't have the measurements but could measure tomorrow. The license plate light is a regular tail light socket for an 1156 type bulb as I recall, which pushes into the large center hole. The license plate bracket does not have a gasket - but it should and I may make one when the car is put back together and at the same time put the correct trunk handle on it. Running a license plate below the tailpan is a PITA - it will get bent or broken in short order. Whenever I have done that I have reverse mounted a 1970s GM flip up license plate bracket which used to hide the filler neck on Caprice, Olds Regal etc., but in the end I have just put them back out of harm's way....
  3. Weasel
    Weasel
    Here's what it looks like without the license plate mounted....
    Baron likes this.
  4. 440 deluxe
    440 deluxe
    weasel i need some update pics on your coupe. btw, thanks for the help on the wind wings they are in the mail.
  5. Steves32
    Steves32
    from So Cal
    Still looking for measurements. I'd hate to guess just from the pics.
  6. violet springs
    violet springs
    see if this helps
    1934coupe and Baron like this.
  7. Steves32
    Steves32
    from So Cal
    Helps?
    That's perfect!!!
    Thanks, you are a life saver!
    I thought I was going to have to go to car shows looking for Willys armed w/ a tape measure.
    Thanks!
    Baron likes this.
  8. drumyn29
    drumyn29
    Thats a great drawing and picture, It'll sure help me!
  9. Wlyzman41
    Wlyzman41
    Thanks! It sure has helped me out! It was nice to discover after all these years!
