Projects 31 A modified
Discussion in 'The Hokey Ass Message Board' started by hron13, May 11, 2013.
  1. hron13
    hron13
    from sandy eggo
    Whats up guys just figured I'd actually make a build thread. Building a 31 A rpu without a bed, classic lakes modified style, on a 32 frame. Drivetrain is going to be a 302 ford stroked out to 331, with a t5, backed by a winters champ quickchange rear. Any way here are some pictures of progress so far.
    At this point the cowl has been dropped about 3/4 of an inch, the pinch is done, I hope to have the frame boxed either this week or next, And have it as a roller by the middle of next month.
  2. JB_roadrage
    JB_roadrage
    Not a bad start, but that's not where the seat goes....
  3. hron13
    hron13
    from sandy eggo
    lol needed a seat while i was cutting out the front cowl mount
  4. fab32
    fab32
    So much for the initial tease, bring on the progress, and by all means all of the pictures you can take.:)
    Frank
  5. Hackerbilt
    Hackerbilt
    Looking good!
    What are your plans for the additional frame length/wheelbase out back?
  6. MATACONCEPTS
    MATACONCEPTS
  7. hron13
    hron13
    from sandy eggo
    frame is pretty much going to be lopped off about 6 inches behind the body the rest of the frame is just there to help keep things square while i build it. rear suspension is going to be a leaf link 4 link using quarter elipticals as the upper arms and a panhard rod.
    and dont worry about pics if i get some work in today Ill take a few for you guys
  8. hron13
    hron13
    from sandy eggo
    got some work done today, installed the flat front crossmember and bobbed the frame (perhaps temporarily, I may put the frame horns back on). Still have to finish some welding and gap filling but it's in
    next project is extending the mini channel to the rear of the body. It isn't sitting flat because the back of the rpu body ends up forcing the rear above the frame rails, so got to cut some notches
  9. alanamhb
    alanamhb
    from new york
    So much for the initial tease, bring on the progress[​IMG]
  10. hron13
    hron13
    from sandy eggo
    Got some stuff done today. Managed to get the front boxing plates tacked in and have some body mounts installed in the frame now. Gonna have to make a few more mounts since if I bolt the body down now the door won't open because it kind of stretches the door jam.
    Nothing to show as of yet. Just chronicling my journey lol
  11. hron13
    hron13
    from sandy eggo
    Frame is boxed and the whole deal has been cut off the frame jig I make just have to build som floor supports and spend the rest of my life grinding down welds. Will post pics later for some reason I can't upload them.
  12. hron13
    hron13
    from sandy eggo
    got the body actually dropped onto the frame, frame is pretty much finished just got to pretty it up some, next step is actually getting the front suspension mounted. Then work moves to the rear
  13. hron13
    hron13
    from sandy eggo
    got some serious work done, front and rear suspension is in, rear suspension got a bit altered from my original idea, went with a 3 link panhard bar, with the quarter elliptical springs being the lower arms, I plan on adding a torque arm if I get too much axle wrap. front suspension is just a split wishbone set up with spring behind, plan on adding a panhard bar in the front as well, but that is for later lol.
