Oil filter help
Discussion in 'The Hokey Ass Message Board' started by tom gorney, May 14, 2013.
  1. tom gorney
    tom gorney
    from chicago
    Hello everyone, I just got one of those orange external oil filters for my 55 dodge. How do you plumb this to the engine?
  2. 73RR
    73RR
    Orange external ???
    Which engine?
    Pic of your parts pile?
  3. tom gorney
    tom gorney
    from chicago
    This is a 1951 218 flat 6.
    I got a external old type filter for it, I was told to route the top of the filter to a oil pressure port and the bottom goes back to the pan.The picture is from Google but it is the same one I have.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Just be sure you have a restriction in the pressure line fitting at the can.
  5. tom gorney
    tom gorney
    from chicago
    But does it then just go down to the pan?
    If so then I need some thing welded on the oil pan.
  6. 73RR
    73RR
    Have you checked in with the guys over at www.p15-d24.com ? The Mopar I6 is their playground.
  7. mustang6147
    mustang6147
    from Kent, Ohio
    By the way, the arogance when your thread is responded to over at the P15D24 forums is normal. Don't take it personal...
  8. freezerburn
    freezerburn
    Hey, mine is made so that it pushes flow up from the bottom and out the top and back to the engine. However mine is a sock type and predates my car by 20-30 years and it's a '48! Anyway look and make sure that the ends of the filter are identical on top and on the bottom... and match that to what makes the most sense to you. The smallest difference when mated into the housing will be very important to flow! I would go by that over any standard answer that you may receive (including my own)- freezerburn
  9. C-1-PW
    C-1-PW
    This should help.
    Be sure to plumb the filter correctly. Some filter "IN" at the top and "OUT" at the bottom, while others are just the opposite. The oil that leaves the filter housing must return to the port immediately above the oil pressure relief valve on the engine.
  10. tom gorney
    tom gorney
    from chicago
    My in-pipe has a .053 hole in it, is that good?
  11. C-1-PW
    C-1-PW
    I vote yes!
    1. .053, will allow for a pretty good squirt of oil at 40--60 lbs.
    2. This is a bypass filter, not a full flow. Therefore, the oil is intended to flow through the canister at a slow rate.
    3. Your actual oil pressure inside the canister will be controlled by the pressure relief valve in the engine block. That valve will open and close in relation to the engine oil pressure. The pressure will vary depending on engine speed, oil pump output, and the condition of the engine.
    By the way, if you do not know the condition of your oil pressure relief valve, this would be a good time to take it apart for cleaning and inspection. It is a simple procedure. After removing the square headed cap, you should find a spring and a piston. The only part you will need to replace is a gasket beneath the head of the cap screw. You can cut your own, or contact me and I will send you one.
  12. C-1-PW
    C-1-PW
    Pressure Relief Valve Diagram
