  1. mrbuck
    mrbuck
    from nor cal
  2. mrbuck
    mrbuck
    from nor cal
    Shit can't get the pic off my phone ill be back later with pics
  3. Buzznut
    Buzznut
    I'm all about doing whatever you like, but honestly think these wheels will ruin the look. Those Cragars look right at home on this shoebox. If it were mine, and it's not, I'd do a black roof and lower the stance...but keep the wheels. Those fandangled ones belong on a blinged out 80's Camaro driven by a guy named Guido.
  4. mrbuck
    mrbuck
    from nor cal
    im back lets see if i can get pics now.
    [​IMG]this is the color id like to see. If your feeling wild and want to add some scallops on there too, it also an idea ive been kickin around. I hope this pic is good enough to work if not i can get better ones tomorrow. thanks guys im really excited to see what you can do. But even better it may push the old ladies buttons and let me pull the trigger on getin her painted.
  5. mrbuck
    mrbuck
    from nor cal
    im thinking the pic i uploaded isnt the best, so i found this one online to use as a template. hope it makes life a little easier
  6. Btrsweet
    Btrsweet
    Made this for a Photoshop contest the other day. bit toonie but came out ok
  7. Rot 'n Kustom
    Rot 'n Kustom
    Very cool.
    What software did you use for the rendering?
  8. Btrsweet
    Btrsweet
  9. Btrsweet
    Btrsweet
    This looks bad ass
  10. Buzznut
    Buzznut
    ^^^^ EXACTLY what I meant ^^^^^
  11. gonmad
    gonmad
    Pretty cool! But wrong color, needs to be blue for the Tick!!
    What does Arthur's car look like?!? LOL!!
  12. LN7 NUT
    LN7 NUT
    I was just going to ask if that was for The Tick! :D
  13. Btrsweet
    Btrsweet
    I did make it blue at one point, but it made the glass look kinda funky as they are blue also.
  14. could anyone maby put some 15" astro supremes or tru-spokes with pinner whites on my truck?
  15. Btrsweet
    Btrsweet
  16. Frogz
    Frogz
    Something like that :
    Or maybe with the complete bumper :
  17. Here is my Deuce as it sits now. I have some plans to make it a little more traditional. This car will never be "old school", but I would like to blur the lines more. I know right now it is a bit of a smoothy.
    I want to start off the easy way, with wheel/ tire change. So, can someone show me some wheel and tire changes to it? Maybe some steelies with wide white? Or maybe with the Lobeck look?
    I am going to change the mirrors and I already have the 33 commercial headlights for it as well. Just haven't had the time to swap them out.
    Thanks,
    Glenn
  18. Rot 'n Kustom
    Rot 'n Kustom
    Wheels, tires, headlights, and louvres:
    32Ford3W03 by DaveTartaglia, on Flickr
  19. thanks bitrsweet, doesnt quite have the pop i thought they would...probably stick with my steelies
  20. Btrsweet
    Btrsweet
    Ya Im with you on that unless you change something with the paint bright wheels look off on it.
  21. Btrsweet
    Btrsweet
    This helps add some light to the body and then the wheels fit.
  22. OahuEli
    OahuEli
    from Hawaii
    Maybe this will help, even swapped in a old school sbc. :D
    [​IMG][/URL][/IMG][​IMG]
  23. Btrsweet
    Btrsweet
    Yikes I don't like the pipes. :p
  24. Btrsweet
    Btrsweet
    this looks kinda cool
  25. Thanks for the photo shops of my 32 guys. It really does help to see what some changes might look like. Much appreciated!
  26. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    btrsweet, the F1 Pu above needs a set of 14" cragers with thin whitewalls for the right look... can you make it happen.
    or here is a different one that is a little more bright.
  27. Planning on a 3 or 4 inch chop this winter, going to take an inch or so out from under the windshield then the rest out above the hinge. I would guess you couldn't photoshop an exact 3 and 4 inch chop but a couple that would be close would be cool. Thanks
  28. Rot 'n Kustom
    Rot 'n Kustom
    How's this?
    Fordpu-00 by DaveTartaglia, on Flickr
  29. That's spot on. man the section gone from below the windshield takes away the deputy dog look..
    Can you shop out the 2 trucks in the back ground.
    Thanks again
