Hello I'm new to the post and have question. Iam restoring a 1952 ford f100 the engine has been rebuilt and i would like to use a t-5 transmission instead of the original 3 speed. Could anyone help me as to witch one would work the best. Could use any help from someone who has done this. Thanks. John from florida
Some useful links: Advance adapters, a GOOD company! http://www.advanceadapters.com/categories/adapters/60/ The only reason I didn’t rig up and modify one of their spacers was because they were too thick for my application – but had to mention them, they were very professional and helpful. Speedometer Gears - http://www.transmissioncenter.net/sp...#Misc.%20Gears If you really want to check your trans alignment… http://www.asedan.com/t5b.htm T5 Tech from Inliners site – excellent resource - http://www.inliners.org/ then select “Tech Tips” on the left side and then select “The T5 Tranny Page” (can’t post a direct link for some reason). T5 ID link (5-speeds.com) - http://www.5speeds.com/t5/index.html Another T5 ID link (the BEST one) - http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm Excellent T5 swap and ID article - http://www.flatheadv8.org/ernie/ernie-t5.htm Car Craft article on T5 swaps - http://www.carcraft.com/howto/116_06...ion/index.html T5 info clearing house of sorts – directs you to other T5 resources - http://www.vanpeltsales.com/FH_web/t5_fivespeed.htm T5 Rebuild Instructions by Chris Neighbors - http://pomoforacing.com/tech/T5Rebuild2002.pdf The ACTUAL T5 Service Manual - http://www.ttcautomotive.com/English...ice_Manual.pdf Other member threads for T5 swaps – Brad’s MOST EXCELLENT reference thread for T5 swaps - http://67-72chevytrucks.com/vboard/s...d.php?t=313954 CWT’s MOST EXCELLENT T5 swap thread - http://67-72chevytrucks.com/vboard/s...d.php?t=408694 My t5 vs Tremec thread (I had a few questions!) - http://67-72chevytrucks.com/vboard/s...=1#post4220832
