Features **1941-1946 Chevy Truck Picture Thread**
Discussion in 'The Hokey Ass Message Board' started by Arrowood Rod & Kustom, Sep 23, 2010.
  1. volvobrynk
    volvobrynk
    from Denmark
    Frame width should be the same, 36 inch across the the crossemember. Acording to chevy old manual projekt.
    The crash box is seized up, so I will throw it out.
    The plan is to use a Volvo straight six standing under my shop bench, to keep the price down on the whole projekt. Another low budget build.
    I haven't found many dual rear ends, but you wouldent use that rearend in the picture. Can you see what that end is?
    The plan is to use a cab from and old Volvo truck. The one I found is of a BE-GE cab, the cab that sat on most Volvo trucks from 50-70. Try Google Volvo Viking, Titan or N88.
    I would prefere the art deco cab, but I've only found a hood as yet. But still looking out for art deco stuff.
    What is the BCD on these truck in the front? 5 lugs
  2. Novadude55
    Novadude55
    from CA
    I cannot tell from photo what diff that is,
    and not sure what you mean by BCD..
    I searched the volvo stuff, pretty cool,
    just be wary of the coe style,
    since that would be a lot more work,
  3. volvobrynk
    volvobrynk
    from Denmark
    BCD means Bolt Cirkel Diameter.
    I'm not going COE.
  4. Novadude55
    Novadude55
    from CA
  5. volvobrynk
    volvobrynk
    from Denmark
    Yeah, thats the one i used. It only States that it's 5 lugs in front and 10 lugs rear. 7 1/4 BCD.
    Does that mean 5x7 1/4 and rear 10x7 1/4?
  6. Novadude55
    Novadude55
    from CA
    I would say that if you measure from two non adjacent studs on the front, that is the measurement you get, 7 1/4 inch, so it would be like saying, 5 on 7 1/4 ..
    Rear might be different, could be a std 10 lug, but I dont know for sure,
    hopefully someone else will chime in,,
  7. volvobrynk
    volvobrynk
    from Denmark
    1.5 tons is what it's allowed to load? whats the trucks weight?
  8. Novadude55
    Novadude55
    from CA
    That is what it's rated to carry,, safely:D
  9. HoosierBuddy
    HoosierBuddy
    from Indiana
    Love that picture!
    Phil
  10. HoosierBuddy
    HoosierBuddy
    from Indiana
    Wow. That's pretty rough. Might make a better planter than a work truck.
    Phil
  11. volvobrynk
    volvobrynk
    from Denmark
    Rough is 15 years ago LOL.
    But frame is good, I found good axels for it.
    I only need frame and ID tags/frame no. Since rest is junk, no need to worry. I love Art deco trucks!
  12. 55Hydramatic
    55Hydramatic
    Until the body falls off when you're driving it!
  13. volvobrynk
    volvobrynk
    from Denmark
    Im trying to find the RPM my motor is gonna run, to do that I need to know how long there is around a 7.50x20 tire. The formel for this stuff would be nice too.
    If some of you guys is totally sharp on this maters, rearend is 5.43.1.
    Its a rearend of a 1952 AD Truck with dual rear tires.
  14. Locomotive Breath
    Locomotive Breath
    from Texas
    7.50-20's are about 36 inches tall. Here is a formula for you (60 mph x 340 x 5.43 gear ratio / 36 inch tall tires) = 3077 rpm.
    Or you can just use this link http://www.wallaceracing.com/calcmph.php
  15. deerchooper
    deerchooper
    i drove it out of my buddies garage today. had to do the iv bottle but it went well.
    you can see some of the floor in the truck, aluminum (5/8"fuel line) heater core lines that goes into the cab. running lights are turned on in one pic.
  16. lockwoodkustoms
    lockwoodkustoms
    Well I had it out for a test run was going to do another run arounds the nieghbor hood and this is what it looks like out doors. :D
  17. KROWN Kustoms
    KROWN Kustoms
    My old jalopy 41
  18. Little Terry
    Little Terry
    Looks good Lockwood. Is it running the stock chassis? LT
  19. 1960's C10
    1960's C10
    from Minnesota
    Here my 1946, 235 6cyl with a castiron power-glide, nova rear-end and mustang II suspension
  20. lockwoodkustoms
    lockwoodkustoms
    Nope, it has an S10 chassis under it :eek:. This is from the other day when it was nice out thought maybe you can see it better. I have a build thread on it here check it out.
  21. Novadude55
    Novadude55
    from CA
    If I may give you some advice, if you plan on driving it a lot,
    dump that cast iron power glide and change to a turbo 350,
    u will get 3 speeds, and a lighter case, and better cooling,
    cast iron retains too much heat,
    Love your truck, :cool:
  22. 1960's C10
    1960's C10
    from Minnesota
    Hi Novadude55, thanks for the comments, the plan is to swap out that powerglide in the near future(?). It is a tank but it sure works great for now. I am planning a 610 mile roadtrip to Rapid City, SD this July. I need to buy an adapter plate to mate the 235 to the turbo 350. Regards...Steve
  23. 46luke
    46luke
    from Iowa
    After being in the shop for almost a year, I finally got my truck back. A lot more work was supposed to be done, but at least it got painted and the tank moved to the back. I will say I'm satisfied with the paint. I chose British Race Car Green and Black.
    eye bone likes this.
  24. Novadude55
    Novadude55
    from CA
    Lookin good, what motor and trans? Frame?
  25. Are those the 47-54 filler strips between bed and running board ? They look good whatever they are.
  26. studeynut
    studeynut
    1945 bus with Cummins desiel
  27. odass
    odass
    from se ok
    I know this may be a little off subject but does anybody have pics of the door rubbers and pinch welds installed on the doors and cab ? I can't seem to find any, I'm fixing to paint inside mine and was wondering what they look like. do these seal up very good or do they leak water and air bad
  28. flyboys101
    flyboys101
    from nj
    Dude, Love that bus! Looking for something similar for my business. Post more pictures.
  29. david_mark
    david_mark
    Big T nailed that picture
  30. odass
    odass
    from se ok
    I think that's 47- 54 fillers, bed, and rear fenders
