"Beside the Barn" willys find
Discussion in 'The Hokey Ass Message Board' started by ME.GASSER, Jun 2, 2010.
  1. hugh m
    hugh m
    from ct.
  2. Nice looks good. Inspiration for the rest of us in the build stage
  3. tolsmith
    tolsmith
    That's unreal. Good luck with her.
  4. The37Kid
    The37Kid
    That must be such a joy to block sand. I'm a big fan of muiti coats of primer, it may cost a bit, but what good is it having leftover primer in a can? Bob [​IMG]
  5. ME.GASSER
    ME.GASSER
    We used 2 gallons to do the all the body parts. With three of us sanding it went fast, We waited 2 week between the last 2 coats. I wanted to give the primer time to shrink!!! My bodyshop buddy knew that my hands needed a break and he needed to catch up on some collision work. It worked out good for both of us.
  6. Stuwillys
    Stuwillys
    Looks really good.
  7. 41GASSER
    41GASSER
    The day I brought my 1940 Willys shell home. My wife was not impressed, no floor, rockers or firewall.
  8. pontman
    pontman
    She will get over it! Where in Warshington did you find that?
  9. ME.GASSER
    ME.GASSER
    I have been on a few excursions with my friends and I have a picture somewhere that looks just like that. We have dragged a lot less than that home before. My wife understands that I suffer heavily from Willitis!!! good luck with your project. The sedan floor pan swap is a great way to fix that coupe. LARRY
  10. Barn Find
    Barn Find
    from Missouri
  11. I have a similar sickness but it is henryJitus
    Sent from my DROID device using the TJJ mobile app
  12. ME.GASSER
    ME.GASSER
    I have a friend in New Hampshire with that very same illness. I can PM you his phone number and you can console each other.
  13. I'm actually going to pick up another 1 Friday it's a sickness
  14. brian55lvr
    brian55lvr
    from ma
    lmao---------looking good
  15. Baron
    Baron
    We really need to form some sort of support group ! ;)
  16. Inland empire hot rods
    from so cal
    Not sure how I missed this post, but I'm onboard now! Keep up the work, its going to be awesome
  17. racer67x
    racer67x
    looks good with the stock pans in the rear but I still gotta smile looking at those old weight jacks in the "before" pic..someone put alot of time into that trick setup.
  18. 37willysgasser
    37willysgasser
    very nice, its come a long way great job!
  19. ME.GASSER
    ME.GASSER
    Thanks for the compliments. Larry
  20. farmer12
    farmer12
    Just read through the whole build thread.WOW! Absolutely awesome work so far!
  21. gearhead78
    gearhead78
    from Dallas TX
    Excellent metal work. What you have done with this car is inspiring.
  22. Beautiful job !! Cannot wait to see the frame and future progress as the build continues.
  23. ME.GASSER
    ME.GASSER
    It's been awhile since I've had time to work on the Mystery Willys. In the last couple of months I was able to strip down the frame that I purchased. I boxed the rails and built a new x-member. The picture shows the drop out transmission cross member and the modification to the front cross member. I didn't want to modify the firewall so I had to move the cross member to have room for the motor. [​IMG]
  24. ME.GASSER
    ME.GASSER
    This is the jig that I use to make my ladder bars. [​IMG]
  25. ME.GASSER
    ME.GASSER
    The rolling chassis. The next few pictures will be of the ladder bar setup. A few people have asked me to send pictures of this setup. [​IMG]
  26. ME.GASSER
    ME.GASSER
    Side view showing the floating link at the front of the ladder bar. There is a bushing through the frame with a bolt that holds the link. This link allows the ladder bar to move backwards so that it doesn't bind the spring.[​IMG]
  27. The37Kid
    The37Kid
    Always good to see your progress reports. Bob
  28. ME.GASSER
    ME.GASSER
    View looking down from the top. The bolt will be grade 8 with a locking nut. There will also be a safety chain in case the rod end breaks.[​IMG]
  29. ME.GASSER
    ME.GASSER
    Close up side view.[​IMG]
  30. ME.GASSER
    ME.GASSER
    Rear housing brackets and shock mount.[​IMG]
