Can anyone office some assistance on how to repair the roof on the 54 210? just about the windo where the door meets the windo frame by the rain gutter on the the top its rusted bad. what do i need to to repair this correctly?
If your good with metal work then some 18 gague sheet metal if not then a donor piece of another car.
Here's how, this is an abbreviated series of steps to to make a roof patch panel. I had to do three sides of my 62 F100. Make sure you are back to clean metal inside and out. Make sure you get some kind of rust coating under the patch, I used weld through primer on the back of the patch. And used Eastwood's Rust Encapsulator on the rusty inner structure after cleaning as best I could.. Good luck...
