for those of you with chopped tops, are you running a windshield wiper? if so where did you get it or what did you make it from?
Whether the car or truck is chopped or not a universal windshield wiper motor from any rod parts dealer will do the job. HRP
thanks ill check into them, I got one from speedway but it isn't short enough and doesnt look like it should be cut
You might even check into the wipers on headlights. I picked up some wiper arms off of a BMW that are really short.
I would think you would leave the stock wiper motor alone. Take the wiper arms and cut them down or replace with shorter ones, and put on shorter blades.
I think there's a thread where someone used MG wiper stands and remote mounted wiper motor. Stock arms are fairly short with those.
