32 Ford steering arm issue
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Feb 21, 2013.
  1. harleycontracter
    harleycontracter
    Put my front end together. My steering arm is hitting my adjustable spring perches. I read somewhere the resolve is to bend them. Can someone tell me how or show me a pic of how to?
    Thanks
  2. metal man
    metal man
    Show us a picture of what you are dealing with. We don't even know what steering arms you are using.
  3. harleycontracter
    harleycontracter
    Ok I'll take a pic tomorrow Its at my shop. Original 32 Ford axle and original 32 spindles Steering arm hits side of my adjustable spring perches. Bought an original set of perches but the shaft is too short to use with my 33 bones
  4. superchargednailhead
    I don't get it what shaft is to short? That's what you get for using that repop junk. Lol
  5. Mr.Musico
    Mr.Musico
    from SoCal
    even if your shaft is short, never admit to it publicly
  6. superchargednailhead
    Good point
  7. Jimmy2car
    Jimmy2car
    from No. Cal
    Are you talking about the steering arm that is part of the spindle?
  8. el Scotto
    el Scotto
    from Tracy, CA
    This is at least the third post you've made regarding this issue! :D
  9. 343w
    343w
    Picture of the problem is needed to solve the issue as mentioned! There are many posts on bending spindle arms as well.
  10. SUHRsc
    SUHRsc
    32-36 axle - 32-34 wishbone - 32-34 spindles....
    should all work out with 32-34 spring perches without any problems
  11. superchargednailhead
    I agree
  12. harleycontracter
    harleycontracter
    I bought 32 Ford spring perches to use tith my 32 Axle and 33 Bones. Length of the perch shaft is too short Can't screw the nut on the end. I bought all original parts to make sure it would all work but not the case. I ask questions again because I'm trying to figure it out but haven't yet. Most guys on here have helped me along and i appreciate all the help[ I will take pics ad post them. thanks
  13. harleycontracter
    harleycontracter
    Just thinking................. Could they be Model A perches and I got taken?
  14. 117harv
    117harv
    Maybe some threads were cut off because they were damaged from removal?
  15. harleycontracter
    harleycontracter
  16. superchargednailhead
    32 and 34 spring perches are the same. I'm setting my front end up now
    32 spring perches 34 bones split a 32 axle everything just bolts together no problem. If your building a early car throw the adjustable perches in the trash. I would agree sounds like the original perches have been cut.
  17. Nope those fit too.
  18. HellsHotRods
    HellsHotRods
    I also agree !!!
    I also don't think adjustable spring perches belong on any hot rod, especially a traditional one. Those parts are for the street rod crowd.
  19. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Just bent a customers stock 32 steering arm yesterday to follow the contour of the dropped axle and there is no way it would clear an adjustable perch on the drivers side. I used spring perch's from P&Js and everything cleared good. Perch was long enough that I used a lower bolt on shock mount that the customer requested.
  20. Pictures work so well, you should try it.
    Here are the perches you mention, A on the left '32/4 on the right.
    Also, dropped Model A axle mocked up with '32 spindle and perches, plenty of stub sticking out the bottom.
  21. Dave50
    Dave50
