Giday, Ilive in Brisbane Australia and having trouble finding a heater firewall gasket kit with no AC, if anybody knows where i can locate one would be great, Cheers, Ken.
Trace out the gasket or the heater box on a sheet of the solid black foam tool box drawer liner. Cut it out, punchout the bolt holes, install! The foam drawer liner is good stuff,and works well I've used it for the same purpose! Good luck! KK
I use the foam that is available at the Joanns,very much like tool drawer stuff. It is like a 1.00 sheet .I tested it and would not melt with a heat gun. Jack
Chek with McVey's in Knasas...add a www and a dot com to that name...they carry lots of Caddy stuff...also USA parts...they also carry lots of Caddy stuff...and did you try Lynn Steele rubber in Denver, NC, ..??? Add www's and dot.coms to those as well...or Google 'em... R-
