My model a sedan currently has a 1952 flathead out of a pickup truck. I have came to conclusion that it has a crack in the block somewhere due to its overheating issues. Here is a post that I did to show what exactly went on and how I tried to debug everything. http://www.jalopyjournal.com/forum/showthread.php?t=724835 So I had this other empty block laying around and figured that I would build it up and completely go through everything in it and make sure that it would have no future problems. I am going to use my thickstun intake, strombergs, water pumps, powergen alternator generator, elelbrock heads, lake headers, and bubba's distributor from my current engine. All of the parts listed are either new or refirbished to be good as new. I plan on upgrading the cam to somethings a little bit more powerful than a stock cam. I want it to sound mean but still run like a top and not have to fight it.
Here is my current setup. Stock except for intake, carbs, headers, alternator/generator, heads, and distributor.
I use my badly cracked block for porting and reliveing practice... By the way you set up looks killer. What cam do you have already ?
Thanks mastergun. Just trying to keep it simple looking. Right now my cam is the stock one that came out of the 52 pickup originally. I want something that is a little bit of an upgrade. I was thinking about an isky max-1.
I am putting a max 1 in my 8ba . Based mainly on Joe Abblin's advise. He told me it iw a good cam for a street car. I'm running one of Joe's blower setups , And for my truck he said IThe max-1 is by far the best choice.
Got the "new" block magnafluxed and no signs of any cracks. I've heard about using chevy valves. Does that require bigger seats? How does this work?
Ol' Ron on the Ford Barn really likes the Literio L 100. It has a great lopey idle, but very streetable. He uses them in almost all his builds. Matt
My "new" block finally got checked and is crack free. It's getting the works,,, bored, decked, new cam, valve seats, crank turned, yada yada yada,,, what can be done is being done.
Good idea, mag flux the block. I like and use the Isky Max 1 in mine,...4", .060 over, Mallory, Strombergs and Offy "400" heads. So far, so good
listen to Ol Ron.L100 is a better cam. you said you wanted a choppy cam,Max1 isn't. It is a good stock+ cam. Pressure test is the way to go...
