Projects Olds J-2 or stovebolt six
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Jan 12, 2013.
  1. junkyardjeff
    junkyardjeff
    For the last few years I have been trying to get rid of a rattle in the 235 in my 37 Chevy p/u that will eventually be fatal so I picked up another 235 and have been considering converting a early 235 to full oil pressure but I really like the Olds rocket,I have been offered a 57 J-2 motor and seriously considering it since it would be much quicker then a old stovebolt. I hate to give up on the 235 since over the last few years I have been making it look like a 216 and want to keep a six under the hood but I want another rocket powered hotrod and dont want to bring another vehicle home,to me the Olds rocket is the best motor GM ever made so I think I am going to give up on the six and put more power in the 37.
  2. GOATROPER02
    GOATROPER02
    from OHIO
    Your just answered your own question.....
    Tony
  3. belair
    belair
    No question-the Rocket. Looks, power, looks, power,. Did I say they look great and make power? Go Olds, man.
  4. Thunderroad312
    Thunderroad312
    Do it, and don't look back. I vote for the Olds.
  5. junkyardjeff
    junkyardjeff
    I am going to measure the motor and see if it will fit in my 37,the Olds motor I really want is a 59 371 since I had one years ago but they are a little wider then the 58 on back. I spent so much time trying to make the 235 look like a 216 I hate to give up but it would be much more enjoyable and not have the usual boring 350/350 in it.
  6. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    303, 324, 371, and 394 are the same across the back of the block.
  7. das858
    das858
  8. mailerguy1
    mailerguy1
    Olds rocket!!!
  9. I like 235's but you can't go wrong with a rocket!
  10. junkyardjeff
    junkyardjeff
    I put a 59 371 in a 53 88 and it was definately wider then the 303 that was originally in it.
  11. F&J
    F&J
    Look at the thread from yesterday "37 Pontiac sedan found"
    It has a 57-58 Olds, engine compartment should be the same.
    I have seen a couple 37-8 chevy coupes running Olds. They fit
    J2 trips:410 to 415 Ft Lbs torque at 2600 ...Yikes
  12. Thunderroad312
    Thunderroad312
    '57-up have a taller deck heigth which makes them slightly wider
  13. Normant93
    Normant93
    I'll trade you a Chevy 261 for that Rocket, I'd love to put that in my 46 Chevy truck!
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    Olds for sure. They fit well in there. I had a 371 in a 40 Chevy coupe a long time ago and it went in like it belonged.
    Don
  15. lawman
    lawman
    Old's,Old's or maybe an Old's J2 !!!!!! LOL
  16. ceresco
    ceresco
    from nebraska
    I have a 1947 Ford coupe with an Olds 324 engine and had always wanted a J2 to put in it. Please let me know if you are not going to use the J2.
  17. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    A 371 is a 371 is a 371.
    Then the front of the block would be just as wide. He should have clairified, he was talking about deck height.
