Butt welding made easy!
Discussion in 'The Hokey Ass Message Board' started by fitzee, Dec 7, 2012.
  1. titus
    titus
    Thats what i do, works nice.
  2. 1nos487
    1nos487
    from east TN
    Thanks for the tips, really helps a rookie.
  3. How might I use this method and technique on the sectioning and stretching of a 60 C60 LCF truck hood that I hope to extend in length another 14" and change into a 60 C10 hood?
    I was going to use portions of a 66 hood that I have for the sides but haven't figured the top & middle out just yet...
    Excellent tech - thank you.
    bob
  4. Bigdavid
    Bigdavid
    from Tennessee
    I really like that approach to patching this HAMB outfit is awesome I've learned a lot lurking around on the HAMB
    <input id="gwProxy" type="hidden"><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
  5. fiddychevy
    fiddychevy
    from pa
    Great idea. Thanks for sharing
  6. hozem396
    hozem396
    from ohio
    I am not a welder by any means but this i great information for us guys that use all the tips they can get!
  7. docmike
    docmike
    Note to self......
    Doc
  8. RangeRansom
    RangeRansom
    great info for us new H.A.M.B.sters!!!
  9. boutlaw
    boutlaw
    Just finished some patch panels on the F1 fenders, wish I had seen this tech first. Great idea. thanks for posting.
    BOutlaw
  10. fleetside66
    fleetside66
    Sure, now you tell us! Really, that's pretty slick.
  11. This thread sure is helpful to me. When I start patching the cab on my COE, this will help a lot. I have never patched panels before, I'm new at welding anything much, only having my first mig welder a year or so & using it for od jobs around the house so far. But my cab is off frame now, I've already cut out a couple front corner patches, which this method may be two late for these, but I have a real long section along the back bottom of the cab that this method should make an easier panel to work on. I am always watching for these kinds of helpful tips. It makes me want to jump in @ start on it while it's fresh in my head...
    Thank you for the thread fitzee, keep it up. I would like to add you to my list & hopefully be able to ask you for guidance later as I start patching & working my sheet metal back in to shape, if you don't mind???
  12. rawcjw19
    rawcjw19
    Great thread thanks for sharing. Stiill can't figure out how you make it look that good. I am attempting to butt weld my first patch panels. How much do you planish each spot weld? I am using a wire feed with .023 wire, cutting the panel with .040 wheel. Very little gap. spot welded 1 inch apart I grind down the spots and hammer and dolly, then spot weld again next to the previous spots all the way around the patch. and I am still getting a little wave, or high spot. Am I hammering the spot welds to much?
    Very frustrating
  13. rawcjw19
    rawcjw19
    Anymore tips?
  14. fitzee
    fitzee
    well first off I dont hammer the welds.. when you hammer the spot welds will distort the metal around it.. I try not to push on the metal or pull it while welding..I prefer to let the metal sit at rest when welding.Ill work the metal till it sits where I want it then weld it. you can hammer weld it after it is all welded.. If I can I will weld the back side of the panel where I can as well.
