Chevy 350, 72 lineage where does my kickdown linkage hook to? And what am I missing to make the connection? Thanks HAMB!
Unless I am mistaken (very well could be) you are missing the slotted eye at the end of the cable and a corresponding stud.....th 350?
Yes sir you are correct. There should be a plastic clip on end of cable and a stud it snaps onto on the throttle arm.
This is what most of the stock setups look like. This is a setup from Lokar. You may need to buy a whole new cable if you can't get the piece that goes on the end of yours. Note that the stud on the throttle arm has a flat head and not a ball end. You might need to make a trip to a junk yard to get the parts you need.
