Projects The 59 LCF begins
Discussion in 'The Hokey Ass Message Board' started by cowoc58, Dec 2, 2012.
  1. cowoc58
    cowoc58
    Sent from my DROID device using the TJJ mobile app
  2. cowoc58
    cowoc58
  3. lcfman
    lcfman
    from tn
    Keep us posted on your progress. Whats your build plan?
  4. JJK
    JJK
    Truck, boat, truck! Whoooooo it's about damn time!
  5. cowoc58
    cowoc58
    About to bolt in an already bagged 80's one ton crossmember... Just have to clean and paint...
  6. wow, I finally have seen another one. I have a 57 lcf, that is in getting paint and body.. home soon. I mounted the cab on a 1980 Chevy 1 ton, rolling chassis.. they sure are kool looking. oh ya, I flatened the floor so I could fit my big feet in there, and the engine is mounted behind the cab... soon I will learn how to put up pics...Lloyd
  7. Is the late 80's crossmember as simple as a bolt-on, or do you have to make spacers?
  8. cowoc58
    cowoc58
    All painted and ready to bolt in..
  9. cowoc58
    cowoc58
    Now the front is bagged with 3 inch drop spindles. The pics are from my phone with a terrible light In the back ground...
  10. cowoc58
    cowoc58
    I need at least a 19.5 wheel to look proportional I believe... The tire is currently 30 inches tall... I think I need a 33 or 34. Here's another cool lcf..
  11. cowoc58
    cowoc58
    My back cab wall and roof are fried so a big window cab donor is on the list...
  12. cowoc58
    cowoc58
    The truck is already mounted on an 80's frame so this is a direct bolt in.. to use the cross member on the original frame would have taken modification... They are close in width though..
  13. cowoc58
    cowoc58
    Donor
  14. Frankie47
    Frankie47
    from omaha ne.
    LCF?..........:confused:
  15. hey Cowoc, that is mine in the other pics.. the one with the big back window...what a cowincidence....lol Rockin Rebel
  16. oh ya Frankie, it means Low cab, Forward
  17. Low Cab Forward. It was the "new" terminology that replaced COE(Cab Over Engine) ;)
  18. schaefer
    schaefer
    Lookin' good cowoc58! My buddy Andrew and I did the work on this one for rockin rebel on here:
    We had to change the roof because the rear corners of the cab were banged up pretty bad from a tilt deck that was on the original frame, and mice had been living in the roofs inner structure and it was rusted from the inside, plus the big back window looks way cooler! We mounted the cab on an '80s GM 1 ton frame that was already stretched and had the flat deck already. I heard that this truck was getting body work recently but I haven't seen it in a couple of years.
  19. schaefer
    schaefer
    Oh, rockin rebel posted on here while I was trying to get my pictures to load, ha ha!
  20. Frankie47
    Frankie47
    from omaha ne.
    Thank you also Rockin Rebel!
  21. No, LCF was a term used by Chevy when these trucks were new. It is a old term and there is a difference between a LCF and a COE.
  22. I think that's what I said...:confused: It's what I meant anyway. ;)
  23. jammersspeed
    jammersspeed
    from herman mn.
    looking good! i also have a L.C.F. I am working on... mine is a 57.
  24. I read it different the first time, but going back I see what you meant....Sorry.
    regardless, here are some pictures. I think they are cool.
      13.7 KB
      11 KB
  25. cowoc58
    cowoc58
    This is turning into a really cool thread.. Thank yall for all of the responces.. This is one of the coolest things I have ever worked on...
  26. Frankie47
    Frankie47
    from omaha ne.
  27. CGkidd
    CGkidd
    Looks cool. Can't wait to see more.
  28. 53 COE
    53 COE
    from PNW
    What - You have not seen BIG BERTHA .....
    :eek:
      93.1 KB
      85.2 KB
  29. cowoc58
    cowoc58
    Big Bertha looks to have had a pretty hefty budget... I wish the fleet side wasn't cut off... That's a great idea... I love the big wheels... Thanks for posting that...
  30. cowoc58
    cowoc58
    Replace the roof skin and back cab wall with a big window... Well I helped.. my friend Nathan Lindsey did the hard work...
