any falcon owners here? lets see some pics!!
Discussion in 'The Hokey Ass Message Board' started by BACK TO THE FUTURA, Apr 29, 2011.
  1. garvinzoom
    garvinzoom
  2. 64ONEOFF
    64ONEOFF
    from Md.
    Go on social groups....There is one just for FALCONS.
  3. Powerband
    Powerband
    [​IMG] <> [​IMG] <>[​IMG]<> [​IMG]
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> '63 Wagon w/ miles per’formance six:
    OEM C8DE Ford 170, Precision Machine worked D7 Head . Oversize intake valves/1.50 exh with- silicon springs and HD retainers, . Milled head w/ Steel Shim Gasket. CR= 9.5:1. H/W 5200 - 2.8 series (32/36) progressive 2Bbl carb., Exhaust ¾ siamese port divider, Re-Curved Duraspark electronic distributor, Champion racing spark plugs, Diaphragm Clutch. T5 Adaptor/5speed tranny, Short throw Hurst Indy shifter, OEM 3.50: rear, Shelby sway bar, , Fabricated subframe connectors / crossmember, Hooker 6601 dual out longtube headers. Shoulder belts front and belts for three in rear, Dual chamber master cylinder, OEM wide-wagon brakes, dual line rear air shocks, 14” wheels & tires, Countersprung Tailgate, Original tube radio …
    <!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->
  4. ford495051
    ford495051
    Here's mine...
  5. Heres my XP Fairmont
  6. joee
    joee
    mst-2 /8"/c-4/306 roller
  7. garvinzoom
    garvinzoom
    Love it pinup65!
  8. von zipper
    von zipper
    Can I slip my Daily Driver Ranchero in here???? ImageUploadedByTapatalk1355069132.079793.jpg ImageUploadedByTapatalk1355069181.031559.jpg ImageUploadedByTapatalk1355069210.496236.jpg ImageUploadedByTapatalk1355069285.564592.jpg
  9. Dan in Canada
    Dan in Canada
    This is my '62.
  10. spuds
    spuds
    from Idaho
  11. CL*falcon
    CL*falcon
    from sweden
  12. just landed in my garage .... 260 V8, 2 barrel, 4 speed, Sprint ... needs TLC ...
  13. Sidewinder777
    Sidewinder777
    from Dayton,Nv
    Here is my '64 ranchero...i know not a falcon...or is it?;)
  14. cage66
    cage66
    from reno
    Heres my 61 deluxe wagon
  15. Taylorengines
    Taylorengines
    from Brea, Ca.
  16. Faus
    Faus
    Here's some falcons I wish I had: ImageUploadedByTJJ1356758062.593286.jpg ImageUploadedByTJJ1356758099.088170.jpg ImageUploadedByTJJ1356758119.440431.jpg ImageUploadedByTJJ1356758138.206184.jpg ImageUploadedByTJJ1356758149.961216.jpg
  17. bathcollector
    bathcollector
    Hey Andy, i bought a 65 XP hardtop project last year. My second 65 H/T, had a 66 H/T inbetween. Pic is in the Falcons done right #1996. Gary.
  18. shoebox302
    shoebox302
    from Boston
    This is my 63 1/2 Futura factory V8 hardtop in progress. All new 65 front suspension components including control arms and steering box, all rebuilt 289, new C4, Lokar floor shifter, 14" stock mustang wheels with spider caps and rings, Hope to drive it this spring.
  19. Steven Brower
    Steven Brower
    Just uploaded some progress pics. Not sure I'm doing this right. Pics should show up under 63 Falcon Futura. It's a convertable - everything has been torn out & its on the road to recovery. Should be on the road this summer!
  20. Billy
    Billy
    Dan from Canada, I love your little bird's stance. Can you share the details, please? Cut 2 coils and two inch blocks out back, or???
  21. tpw35
    tpw35
    Heres mine, just finishing it up and working the bugs out, still has the break in oil in it.
  22. Billy
    Billy
    TPW35... Daddy like!!!
