Butt welding made easy!
Discussion in 'The Hokey Ass Message Board' started by fitzee, Dec 7, 2012.
  1. Learned it from my bodyman buddy...used it to patch my 36 ford cab top.
  2. DamnYankeesKustoms
    DamnYankeesKustoms
    Look up Lehigh Valley Abrasives.... One of the best places to get cutoff wheels and such, the Metabo 1/32 ones are my favorite and they are dirt cheap...
  3. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Same here. :D
  4. BrerHair
    BrerHair
  5. GizmoJoe
    GizmoJoe
    I slipped a gear or something.. they are Hitachi discs. :eek: Too many projects and supplies on the go.
    From what I can read off the disc:
    Type 1
    5" x .040" X 7/8" (125mm X 1mm X 22.2mm)
    12,250 rpm max
    Metal, Stainless Steel Thin cutting
    727-570 in another place it has: 7 54005 27570 2
    Use in accordance with EN12413
    They are thinner than the Walter but I haven't tried a Dewalt yet.
    I hope that helps and again.... sorry for the brain-fart on the name.
    Joe
  6. HUSSEY
    HUSSEY
    Sweet, thanks for sharing, you can alawys learn somthing new every day on the HAMB.
  7. vilanar
    vilanar
    from Finland
    Great tech , and when you make round edges on your patch , its easier to metal finish
    it `cause heat don´t concentrate in sharp corners making it to shrink.
  8. 1927Tudor
    1927Tudor
    Great tech, thanks for postin'....
  9. koolkemp
    koolkemp
    This is a great method for butt welding , I use it when ever possible as well.
  10. Kirk Hanning
    Kirk Hanning
    This is a great way to make a patch filler, I've been doing it that way for years. I might add a little something that may make it even easier. Instead of tacking the patch to the panel prior to double cutting I drill through both panels with a 1/8" drill bit and put a cleco through it. This way if anything has to be manipulated you can take out the cleco and drill a new hole for it. This technique is really effective when doing a chop. When the situation warrants it you can let the top slide inside or outside the body then drill & cleco at desired heigth. When chopping a 34' sedan it worked perfectly for around the rear 1/4 and back portion of the body. let a cleco out double cut weld move down another inch and repeat. Try to start in the "middle" of the panel then work each way without jumping around other wise you'll crowd the metal and get a small buckle.
  11. Roadsir
    Roadsir
    My first impression when I read this is that it was more of a "production technique" than a "quality technique", but I stand corrected. I guess the real key is a quality, thin, wheel and the proper angle to insure as little gap as possible to minimize shrinkage.
    Nice job and thanks for posting!
  12. heyitsnate
    heyitsnate
    bookmarked. thank you-very timely, as a have some very large panels to fit. i was wondering how i would do the arch on some inner fenderwells, i'm going to try this from the inside out....
  13. 19Fordy
    19Fordy
    How would you use that same technique to patch a 5 in dia. hole?
  14. cshades
    cshades
    from wi
    I use the same method with the exception of the grinder i use a small air saw.
  15. prpmmp
    prpmmp
    Great job Fitzee!! Do you tig or mig the final welding process? Do you weld then hammer the weld while its still hot? I have trouble with warping! Thanks Pete
  16. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    I am going to try this on my 51 tail light repair kinda tricky area with an extreme curve.
  17. indyjps
    indyjps
  18. haroldd1963
    haroldd1963
    from Peru, IL
  19. Rynothealbino
    Rynothealbino
    Definitely going to try this next time I do some patch panels.
  20. chevyburb
    chevyburb
    A friend of mine that's been building hotrods for 60+years showed me how he replaced the whole back end of a '35 chevy sedan with that technique. He overlayed the existing with the new panel, screwed it together at the overlap, then, using an air saw, cut 3-4 inch strips, peeled back the overlap and tack welded it. It was slick.
  21. After seeing Brent's ride at Indy, I am not surprised to see his clever post on patch panels. Nice work!!
  22. fleet-master
    fleet-master
    This method doesn't really work very well on curved joints ..such as filling in holes. You can get away with a certain ammount if the radius isn't too tight .
    ..Having said that...an air powered hacksaw with a small blade would cut a circle just fine if you have one.
    What you could do when filling in a 5in dia holes is to leave 2 or 3 tabs on the patch and neatly trim them off during the welding process. Or use magnets to hold the patch in place...I do that quite often.
  23. john~N~dallas
    john~N~dallas
    very nice... i will have to try this method soon!!!
  24. striper
    striper
    Place a 5 1/2 inch square over the hole then follow what Fitzee did. Voila...square patch, no hole.
  25. bcowanwheels
    bcowanwheels
    Nothing like being taught by a "craftsman" thanks for the tip.....
  26. Zed
    Zed
    from FRANCE
    thank Fitz for sharing ! i had to try it ! :D
  27. 61 chevy
    61 chevy
    love metal working,
  28. servi53
    servi53
    great tech, very informative and easy to grasp
