Model A Frame Dimensions?
Discussion in 'The Hokey Ass Message Board' started by JimA, Feb 10, 2005.
  1. JimA
    JimA
    Anybody know of a good scan of all the dimentions of a stock A frame? Looking for the distance between all the crossmembers and a plus if it shows the rearend and wishone attachment points, but not manditory. Thanks Jim
  2. manyolcars
    manyolcars
    wheres that picture of the guy saying, "Not this AGAIN!" ? We really do need a separate forum for all these things that get asked once a week.
  3. fab32
    fab32
    JimA, Don't know for sure if they do the A frame but Wescott's catalog shows the dimensions for the early Ford frames. If that's true I think you can get them off their website.
    Frank
  4. Dan
    Dan
    yeah, I think westscotts does show the A, good site...
  5. JimA
    JimA
    OK, nobody else please add to this- I hadn't seen it in a while and didn't know where to look. Thanks
  6. 30roadster
    30roadster
  7. deuceguy
    deuceguy
  8. Dont be suprised if the numbers vary.......from the chart to your frame.......;)
  9. BELLM
    BELLM
    They will vary, working on a 32 frame recently had been modidied, couple dimensions off from Westcott diagram, checked against another frame I have that has K member still in and checked same.
  10. 30roadster
    30roadster
    yeah...my A frame you could say +/- a quarter of an inch:D
  11. 48fordnut
    48fordnut
    those may be good sites ,but not avail.at least today.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    here ya go
    ha! this thread is 4 years old!
    DOH!
  13. Bull
    Bull
    I, too, need this. Unfortunately I can't enlarge the above pic.
  14. Bull
    Bull
  15. Like this,,
    Lars
  16. budd
    budd
    madel-a frame pic
  17. BratRod
    BratRod
    this may be a silly question but are these measurements the same for all body styles? Are all model a frames the same (tudor, p/u, 4 door)? or am i just missing something
  18. bct
    bct
    short answer ...yes^
  19. fordmechanic
    fordmechanic
    can someone do me a huuuuge favor and draw a vertical line exactly where the firewall is ?
  20. 34 Hound
    34 Hound
    I can't draw the line for you, but I had a look at my stock '30 sedan and the firewall is exactly even with the rear-most of the three holes for the rear engine mount.
  21. 34 Hound
    34 Hound
    Better yet... A picture's worth a thousand words and all.....
  22. fordmechanic
    fordmechanic
    you are the man hound. thanks a ton. im building a custom frame and needed the line to gap my front crossmember.
  23. telecustom
    telecustom
    from Langey, BC
    Cowl line 27+1/8''
  24. fordmechanic
    fordmechanic
    27 and 1/8 from the center of the front crossmember ?
  25. telecustom
    telecustom
    from Langey, BC
    On the chart it reads 10 1/4'' plus 8 1/2'' being 18 3/4'' from cowl line to the front of the middle cross member. It also reads 3 7/8'' is the thickness of the cross member. So 3 7/8'' divided in half plus 18 3/4'' will give you center of cross member to cowl.
    Oh 14 7/8'' plus 12 3/4'' to the back of the front cross member. Doesn't give spec of the width for the front.
