I need some pics or info on where and how the hood hinges mount on the cowl. Are they directly on the cowl, or do they mount on a bracket that goes on the cowl? I bought this car in pieces and am not sure if all the parts are there. Chris
The hinges bolt directly to the cowl, one bolt is inside the car and part of the hinge, and 2 are in the engine compartment.
Ok thanks guys, they may be the same as the 47, I am not sure. Will try to figure out, got a rough idea chris
I took the hood off my 40 last nite, its just like the picture above I can take and post pics if you need
Here are some pics. There are 3 mounting points to the hood and all 3 pivot as it goes up and down. The middle pic should be rotated 90 deg clockwise. The arms in the 1st pic go on the 2 bolts on the left edge of the 3rd pic. The upper end of the arm in the middle pic fasten to the bracket on the left edge of the 3rd pic.I hope this helps.
