Frigging nice build going on here,definitely going to follow this build. Looking forward to seeing it on the streets here in Houston one day.
Thanks, again Alex appreciate all the help through the some of the install Muncie, hopefully at least be driving it by Christmas. Chop will be done probably sometime in March, but custom grill, tailight treatment and rear bumper will be done....see you around
Wanted to add some supports in between the bracing for the notch, cleaned the area up Cut up some tubing and mocked it up Welded them in Posted from the TJJ App for iPhone & iPad
Wire wheeled the frame and start the por-15 3 step process in the morning Posted from the TJJ App for iPhone & iPad
marine cleaner/degreaser While I was waiting for the cleaner and prep to dry after wash down, scuffed my shocks and primed them And painted them black Posted from the TJJ App for iPhone & iPad
Por-15, have a few things left underneath side, panhard bar and a few touch ups....finish it up tomorrow Posted from the TJJ App for iPhone & iPad
Thanks, the smaller can does 96 sq feet I believe and that is plenty. Just make sure you do the three step process. I wired wheeled some of the really dirty areas and was amazed at just what the marine cleaner/degresser pulled of the frame.
Thanks man....dropped the tranny off tonight for the rebuild, so drivetrain should be in by next weekend Posted from the TJJ App for iPhone & iPad
Alright went to Burnout Houston this morning, badass local show. Went to home depot picked up some nuts and bolts and finished putting my bags and shocks on.....enjoy Posted from the TJJ App for iPhone & iPad
Thanks, next update will be the engine and tranny mounted. Hopefully this weekend...later Posted from the TJJ App for iPhone & iPad
