belt buckle, maybe a timing gear with eccentric for some sort of pump. would help if you tell a size.
Not 100% sure but some company made a variable timing chain setup years ago. I remember them from old hot rod magazines, and that might be one of those. Must not have been to sucessful, as you don't see them any more. Don
Right. I think there was a thread in recent times here on that or something very similar. Worked with the combination of the spring and rotational G-force?
I guess the theory was that you could set your timing and that slotted section allowed the timing to advance or retard a certain amount, depending on rpms. Maybe an attempt to maximize performance under various loads and speeds. In addition to the advertisements, I think I recall a magazine feature on those, touting how great it was. Don
Advancing the cam at low speeds will improve HP output. I wonder what they did about ignition timing?
Here is a post on the HAMB from 2009 about these: a popular VAR-I-CAM that was employed on many drag race engines actually employed a spring that would hold it to a predetermined point, and then as rpm increased, the cam would change. this, along with a variable bleed down hydraulic lifter, (RHODES LIFTERS) was a real giant breakthru in the cam speck limited classes at one time. I remember quite a few engines that would really rattle when the driver would let off at the end of a run. VAR-I-CAM was built and sold in SAN DIEGO, Calif.....circa '60's..... Don
Whatever the application, it needed a fuel pump that mounted on the front cover, hence the round drive cam.
