Some where I saw a home made device to slice rubber tubing straight so you can slip it over a metal edge. Anybody have a picture or a referance to the making of such a device. Thank you for your time. Terry
If you're asking what I think you're asking a good way is to grab a 2x4, drill a hole a little bigger than the size of the hose, then cut the 2x4 in half right at the center of the hole. Stick it in your vise with a utility blade wedged between the wood so it only comes halfway up. then draw the hose through the hole..
