track nose dimensions? and a cool idea for a track nose.
Discussion in 'The Hokey Ass Message Board' started by Kage, Oct 22, 2012.
  1. Kage
    Kage
    from Delano, TN
    I thought it would be cool to make a track nose for a 33/34 ford out of an inverted Edsel grill. What do you guys think?
    Does anyone know the dimensions of the track nose on the Pierson brothes coupe? Or any similar style track nose. Height, width, and depth?
  2. Kage
    Kage
    from Delano, TN
    The Edsel grill is 10" wide and 21" tall. It should make an excellent grill opening for a track nose
  3. deadgearhead
    deadgearhead
    from Washington
    I saw a T roadster with a Edsel grill and it looked like hell, and I'm not sure inverting it would be any different. If you look at almost every track nose including the Pierson coupe, they are pretty curved and are slanted back a lot. In case you haven't checked out the vintage sprint car thread here, there are tons of different track noses there and I swear that some of them are dead ringers for sectioned down Oliver tractor grills like this.
  4. 296 V8
    296 V8
    from Nor~Cal
    I never liked the nose on the Pierson brothers coupe ….. I always have liked the one on the so - cal car better.
    A bunch of good lookin ones have been made by simply using the back half’s of 2 late 30’s to ? rear fenders.
  5. Like this?
    (Sucks, personally - just sayin)
  6. BabbitBeater
    BabbitBeater
    from Colorado
    I like the Oliver grill. IMHO.
  7. metal man
    metal man
    Speaking of tractors, if you find the right one, some of the old tractor gas tanks make a nice nose.
  8. Mr48chev
    Those Edsel grills stuck on rods are just WRONG. I've been playing with left over pieces of banged up fenders to make a nose for my boat tail but haven't got anything ready for a photo yet.
  9. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Here is the T
  10. tfeverfred
    tfeverfred
    Oh my.
  11. Roadsir
    Roadsir
    I had one mocked up with a the rear potion of a 48-54 Chev pickup rear fenders. It seemed to be a good fit.
  12. Roadsir
    Roadsir
    A more slender look would be to use 46-48 GM front fender extensions that bolt to the door. You would need to add material between them to get the correct width
  13. Kage
    Kage
    from Delano, TN
    No....i would flip the Edsel grill. I have some sketches i will put up
  14. fur biscuit
    fur biscuit
    for a track nose it won't work. not aesthtically, not litterally, not upside down.
    call it a flipped upsidedown edsel nose grill. the green T is spot on.
    sorry.
  15. chriseakin
    chriseakin
    I think the grill on that brown one is only one of many problems it has and not the most uglifying. The IFS and square headlights are worse and the top looks kinda like it belongs on a covered wagon. That green car is cool.
  16. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    that's got a great profile! any pictures from the front?
  17. Roadsir
    Roadsir
    Unfortunately no...but it didnt take much work to make it look right
  18. Kage
    Kage
    from Delano, TN
    Does anyone know the dimensions of the grill for a 33/34 ford. Height and width where it connects to the hood?
  19. Got any pics of your boat tail? Sounds very interesting!
  20. Kage
    Kage
    from Delano, TN
    here is a rough sketch of what i am talking about
  21. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Kage- Build it. It's your car.
  22. '51 Norm
    '51 Norm
    from colorado
    I always liked Edsel grills, on an Edsel.
    My wife says that I am crazy to like anything Edsel, she may be right.
  23. metalshapes
    metalshapes
    Edsel grilles are cool...
    I put one in a sportscar.
  24. Atwater Mike
    Atwater Mike
    METALSHAPES has it in spades. It is a lesson in proportions.
  25. dad-bud
    dad-bud
    Kage, I like your sketch but ...............
    The pics that show Edsel grilles worked into noses just don't look good tho.
    Maybe you'll pull it off, then again, maybe not. Have a go and see what you think.
    Cheers.
  26. Give it a shot, after all its only an Edsel grill. No real loss if it all goes to waste
  27. re49
    re49
    metalshapes-Is that a Sunbeam-Talbot? Sorry to go o/t.
  28. MikeRose
    MikeRose
    from Yuma, AZ
    Wow Alex, that's awesome.
  29. wsdad
    wsdad
    I like it! Flipping the grill up-side-down puts the wide part at the bottom, which makes it look good to my eye. But when I imagine it on a 34 Ford, I'm not sure it would work up-side-down because of the rest of the car's body lines.
    It didn't work right-side-up on this brown car because it looked out of place with the rest of the nose's lines. I think if it were up-side down, shorter, and rounded back at the top to follow the rest lines of the nose, it would have looked better. Of course, they aren't made out of Play Dough, so that would be a little hard to do.
    It works on this car, because it mimics the lines of the cowl and hood.
    It looks "right" in Metalshape's sports car because the fenders form a V, as does the grill.
    I like this nose by itself. The up-side-down Edsel grill follows the lines of the nose. It would look great on a lakes modified T.
    Also, with it being up-side-down, it wouldn't be immediately obvious that it's an Edsel grill. It could be fun to watch people put it together.
    However, that nose doesn't follow the lines of a 34 Ford. It needs to be wider at the top and narrower at the bottom to fit the lines of the hood, body, and fenders.
    [​IMG][​IMG]
    I can imagine it right-side-up - with it's flat top matching the flat hood and it's narrowing, rounded bottom snuggling nicely between the fenders. It would be narrower than the original grill, so you'd have a lot of solid area on the front of the car. That would give it a nice salt racer look, if that's what you're after.
