Ok , on my 53 ford flathead, I want to take the fan pulley off and leave the one behind it ..... Can you separate those or do i need do i need to buy something to replace it ... I dont want to take it off and mess a rebuilt running motor up ...... Thanks
Hi there are you talking about the bottom crank pully ? I guess you are and you want just the water pump one left ? I've machined a few of them in half just with a lathe ,it gives you a bit of extra clearance that always helps good luck Posted from the TJJ App for iPhone & iPad
Don't know where "In a House" is. But if you were around here i would be happy to part yours off for you.
