Y block flywheel difference
Discussion in 'The Hokey Ass Message Board' started by 1957rider, Oct 8, 2012.
  1. 1957rider
    1957rider
    Hello guys, Im on the hunt for a y block flywheel :D and I had some questions maybe I can gt answered. Is the y block flywheel unique? Can I use a truck flywheel in a car? Thanks.
    Sent from my DROID device using the TJJ mobile app
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    From what I understand they're all the same- and fit from early 54 y-blocks up to the newer 62's...
  3. I'm also pretty sure they are all the same. If in doubt y-blocksforever.com
  4. Ole don
    Ole don
    One for auto, one for stick. Pickup is the same as passenger, but F 6 may be heavier.
  5. 1957rider
    1957rider
    Alright Thanks guys I was a little iffi since I've never dealt with manual transmission flywheel . Thanks again
  6. thunderbirdesq
    thunderbirdesq
    They will all physically bolt up to the crank but are drilled for different size pressure plates. Easy enough to have one redrilled if need be, but something to be aware of so you gather all the correct pieces.
  7. Heo2
    Heo2
    I run the flywheel and 11 inch pressure plate from a F600
    and a 11 inch disc with a 4spd rug no problem
    the flywheel looks the same as a pass flywheel
  8. 1957rider
    1957rider
    How about if I have a t-bird bellhousing? Would a truck flywheel n pressure plate work? Because I am aware that the truck bellhousing is a little bigger! What would be the cause of that?
  9. You should be fine
  10. DenB
    DenB
    from addison IL
    I have 54 flywheel on a 59ish 292 truck motor with T bird bell house connected to a later 50's od three speed w/a Tbird clutch.
    I think you"ll be fine.
  11. There you have it!! A combination of it all. Im sure your set up will be fine.
  12. 64gal
    64gal
    Be carefull, the flywheel from a 64 f100 with the large spline input 3 speed will not fit in a pass bell.
