Maxi Fuse
Discussion in 'The Hokey Ass Message Board' started by dirt t, Oct 11, 2012.
  1. Is there a unit available at a pick a part. What make and year.
    I am looking for a 70 amp fuse.
    Thank you
    Terry
  2. evs1
    evs1
    Standard auto parts store item.
  3. Found one on amazon for less thea $20.00 and free frt.
  4. a40lover
    a40lover
    NAPA has a inline maxi fuse holder, and also circut breakers in all amps.
  5. The Kingman NAPA stands for Never Any Parts Available. Those guys blow donkey nuts. :mad:
  6. CutawayAl
    CutawayAl
    from MI
    Most manufacturers use a fuse link for amperages as high as you are asking about. If you compare the cost for a Maxi fuse and fuse holder to the cost of a short length of fuse wire(fuse link), you will see the biggest reason why they do that.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    More like, No American Parts Available ;):D
  8. that may be true but it's a lot easier to replace a fuse.
  9. CutawayAl
    CutawayAl
    from MI
    I wasn't suggest the you use a fuse link, or that a fuse was better. It's worth noting that airplanes don't have fuse links. My point was that you asked about getting a Maxi-fuse holder at a junk yard. While some cars do have them, it's not too common. Japanese cars seem to have them more often than U.S. cars. Most of the time the fuse holder will be part of a fuse block assy., not free-standing. If I remember correctly some Mazdas have a free-standing Maxi-fuse holder under the hood. If your time is worth anything you will probably be further ahead money wise to just buy what you need new. And, that way you get exactly waht you want. You can get them in various styles, some are even water proof.
  10. Gus68
    Gus68
    from Minnesota
    I thought it was "No-Auto-Parts-Available"....... Sorry.
