I need help identifying this pulley. I want to think its 35-36 only, but not sure. Diameter is 3.75 and hole to hole dimension across are 3.125. It's a single groove pulley I need 1 of these pulleys if anyone can help! Thanks!
I stockpiled a dozen or so pulleys & fans trying to get a combination I was happy with when I was putting my engine together so I will check back when you post a picture- anything like this?
Just searched and measured up all my early generators. They are all the larger diameter. Wish I could have sent you one. BTT for ya Rob
Still no luck finding one of these. If anyone has one let me know! OD is 3.71 according to the Ford green bible. part number 82A-10130 5/8 inch bore Thanks!
I see the one in the picture has the keyway. Is you gen threaded or keyed? Some pulleys would fit either style. Which do you need?
