Trying to find rear trailing arm bushings for a 61 Olds. If I can get a Moog, or similar, parts number, I can look up the dimensions, and maybe find a modern equivilent. To make it simple, I believe all the bushings, upper and lower, are the same size. If not, I guess I can fab up new arms, but trying to keep customer costs down! Anyone have an old catalog collection?
My Moog catalog only lists back to 1964. Part # K5161. Same P/N, upper and lower. Full size and Cutlass used the same part. Cutlass used this part 1964 to 1977. Full size used them 1964 to 1970. My book (1942-1990) shows no listing for 1961. MAYBE this number will work for you...good luck!
Checked out K5161, application is wrong, they start at the 64 models. Also bolt size is too small, and it's not wide enough. Anyone else?
bump. I've got a catalog that goes to '59 here, I think I have one that would cover '61 at home. I'll look tonight. I've got a scan of the 39-59 catalog that I think would help a bunch of guys here.... but its 126mb (huge) and I've no place to host it... anybody have any suggestions?
OK the 1960-1970 chassis catalog lists a K5195 as the upper or lower rear trailing arm bushing for a 62-64 olds rear control arm... no listing for anything at the rear of a 61. now for a 1961-70 cutlass and f-85 the rear bushing is a K5190 on the upper and a K5191 on the lower. I'm guessing that is what you are looking for....
