Is it ok to put a dip in the center of the tie rod?
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Aug 26, 2012.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    Putting together a model a with a gmc 302 straight six in it and my motor mount is under the harmonic balancer and it hits the tie rod. The tie rod goes through my radius rods good like it is so I can't move the steering arms to help. It just needs a little drop in the center to clear the front motor mount. Also since I would lose length I will have to make one from scratch, do I use DOM tubing or something else?
  2. The37Kid
    The37Kid
    It was common on many cars in the 1910 era, so it should work fine today with the proper size tube. Bob
  3. doose32
    doose32
    we have done it on several customers cars, works fine. just make sure jam nuts or tie rod end clamps stay tight. dom is fine,
    www.droppedaxleproductions.com
  4. I'd rather jack the front of the motor up, "a little".
