Is there a company that sells replacement dash pads The top portion of my 63 Fairlane dash is really warped and I would love to replace it. Thanks!
If you looked at that site that whole panel removes. Be careful for the glass even though it is made of plastic it will crack due to age. After you have removed that whole panel you can change the bulbs . Before you replace the panel cut the lights on to make sure all bulbs are working , then replace the panel. Just screws holding it in the dash.
Dearborn Classics sells the dashpad and a lot of other goodies for Fairlanes. If the dash is steel, not sure who carries those. Can it be taken out and straightened like a fender?
Try "just dashes" as a company name. The price used to be $500 for most dashes minus guages, don't know what its now.
