1933 willys model 77
Discussion in 'The Hokey Ass Message Board' started by jan bogert, Sep 8, 2011.
  1. jan bogert
    jan bogert
    does any one know if a coupe body would fit on a four door frame without any cutting?:)
  2. willyscoupe
    willyscoupe
    I have sat a delivery and a Coupe on a Sedan frame , the delivery had some different mounting points but same frame from what I remember .
    I have noticed on my newer 77's ( 35/36 ) there are extensions on the front of the frame for the later style front sheet metal but that could be modified .
    You have a 33 Coupe body ? Steel or Glass ?
  3. A guy locally takes 2 door sedans and makes coupes (model 77) out of them, the floors are the same, I'm not sure of the four doors. His name is Bill Gift in Chambersburg Pa.
  4. kays kustom
    kays kustom
    from california
    hey cpkphil
    are you looking for some 33 parts or a whole body
  5. Weasel
    Weasel
    ^^^Hi Lee - good to see you on here at last....
    1933 and 1934 front sheetmetal will fit 1935 frames and 1936 frames - although there are differences between the two - but only after modification of the front frame horns. All Model 77 Willys bodies will interchange on original frame. It's just the front frame horns and spring hangers which are longer in 1935 & 1936 and thus need to be shortened.
    And yes cpkphil is right, there were no factory Model 77 two door sedans period.
  6. kays kustom
    kays kustom
    from california
    hello
    i only joined last week i think it was
    how are you ??
  7. The37Kid
    The37Kid
    Just to educate us could someone post photos of the 33-34 and 35-36, all these years I thought all Model 77's looked the same. Thanks. Bob
  8. The37Kid
    The37Kid
    Just found the other 77 picture thread with this photo posted by Weasel. Nice looking car, with a color combination that looks good on any car in the 1928-34 era IMO. [​IMG]
  9. The37Kid
    The37Kid
    Here is another Weasel photo with the flat grille. I think I like the above style better. [​IMG]
  10. jhmagill
    jhmagill
    WOW! what an incredible car....
  11. jhmagill
    jhmagill
    anyone have a 35/36 panel or truck? i need some title info. I'm not looking for a title, just some info. thanks
  12. I have a '36 panel. My chassis is probably 33or34 without the extended frame.
  13. willysguy
    willysguy
    from Canada
    With 33-36 coupes so hard to find It would be nice to see some info on converting a 4 dr. I believe the front doors and quarter windows are the same?
  14. Weasel
    Weasel
    ^^^talk to Lee Kay - kays kustom in post #8 above; see his work at www.kayskustommetalworks.com. Lee is the King of Willys sheet metal fabricators and can do a sedan to coupe conversion. Or you could buy my cherry all steel Model 77 coupe....;)
  15. Heres my 35 to compare with.JW[​IMG]
  16. flintstonecharger
    flintstonecharger
    from Mass.
    Quarter windows are different
  17. I think coupe quarter windows are a bit smaller...I have one somewhere, I'll check it against my sedan moulding when I find it.
    g-willys
  18. willysguy
    willysguy
    from Canada
    You know I still want one Bill!
  19. willysguy
    willysguy
    from Canada
    I'll be in the market once my 41 coupe moves on down the road.........
  20. Willysguy,
    If it turns out as nice as your 41, and your duece, I can't wait. Are you coming to the 50's? 25th picnic this year!
    g-willys
  21. willysguy
    willysguy
    from Canada
    I may have to Bill, the picnic anyway...Duane
