what rear end is in my car?
Discussion in 'The Hokey Ass Message Board' started by 51flathead, Apr 26, 2012.
  1. 51flathead
    51flathead
    i have a 1951 chrysler windsor deluxe. what rear end would be in this car? im lookin to change the gears in it, factory one are just way to low
  2. oldcarfart
    oldcarfart
    I believe you would be better changing to a later model rear end than trying to source alternative gear ratios for your axle.
  3. Munster Motors
    Munster Motors
    im guessing 8 1/4 rear
  4. hotrodbill
    hotrodbill
    What he said.
    There is no aftermarket for those rear ends, anything you find will be stock replacement stuff. And they are incredibly weak, with like a 7-1/2 ring gear. Find a later model rear and swap it.
  5. 51flathead
    51flathead
    thats what i was thinkin about, maybe one out of a ranger? hmmm ill have to do some measuring
  6. If you are thinking about going the 8.8 route I would sugest getting one from a '95 or up explorer and not a ranger. If I remeber correctly the explorers have 31' spline axles and the rangers have 28?
  7. keep in mind 28 splined axles will do just fine in that old chrysler he just needs one that is proper width, plus get ready to update braking system when you start changing things.
